Hello Guest it is November 13, 2026, 10:37:08 AM
Author Topic: Problem with "Cycle Jog Step"  (Read 22681 times)
« on: October 08, 2021, 11:31:40 AM »
I have a problem with "Cycle Jog Step". It is set to 0.0100. The first click on the arrow moves the axis by 0.0100, the next by 0.0050, then the next by 0.0150. So sometimes I have that error of 0.0050.
The same thing happens to me when engraving. For example, the depth of the z axis is set to 2 mm and it ends at 1,995.
Can this be corrected somewhere in Mach3 settings?
https://www.youtube.com/watch?v=DVDizysSpRs
Thanks in advance
« Last Edit: October 08, 2021, 11:40:39 AM by Midhat »
Offline kf2qd
  •  157 157
Re: Problem with "Cycle Jog Step"
« Reply #1 on: October 09, 2021, 11:27:46 AM »
That sounds rather bizarre. Make sure the mechanical system is correct, because if there is any mechanical problem the motion system will not correct for it. Is this motion showing up on a DRO or on an indicator?
« Reply #2 on: October 09, 2021, 11:31:26 AM »
I'm sorry I'm a beginner. I don't know what a DRO is?
