Hello Guest it is October 25, 2026, 10:44:21 AM
Author Topic: Probing doesn't move motors  (Read 5393 times)
« on: October 07, 2021, 01:00:27 PM »
I recently changed to mach4 from mach3.  I got everything setup and working yesterday.  Today I ran the softlimits plugin and edited a script so that soft limits are enabled when starting mach4.  Yesterday z probing worked.  Today the motor doesn't move at all when z probing.  Even running G31 in the MDI gets no movement.  I can jog the machine around with no problem.  The indicator light on the Diagnostics Tab is off and if I manually touch the pad to the bit, the light comes on.
« Last Edit: October 07, 2021, 01:11:52 PM by c-wych »
Re: Probing doesn't move motors
« Reply #1 on: October 07, 2021, 02:23:53 PM »
For what its worth, I can open up my old setup in Mach3 and the G31 command works fine.
