Hello
Guest
it is
November 23, 2026, 04:31:33 AM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Mach Discussion
General Mach Discussion
Mach3 does not move axis at all in demo mode
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Mach3 does not move axis at all in demo mode (Read 29325 times)
inaxtor
6
on:
October 05, 2021, 03:05:54 AM »
Had an existing cnc router with control panel RichAuto dsp 11 went down.
Changed over and recabled everything according to Mach3 breakout board for x-axis and y-axis and spindile
VFD comes on Mach3 board comes on with two solid RED lights.
Do I need a license to get this working??
Last Edit: October 05, 2021, 03:14:56 AM by inaxtor
Tweakie.CNC
9,378
Super Kitty
Re: Mach3 does not move axis at all in demo mode
Reply #1 on:
October 05, 2021, 04:01:08 AM »
You do not need a license to get it working.
Only purchase the license when you have your machine working correctly and need to run a Gcode file greater than 500 lines of code.
inaxtor
6
Reply #2 on:
October 10, 2021, 04:40:26 AM »
Seems the the issue is with the driver.
No driver appears in device manager and when I try to add the mach3.inf file as a driver I receive the error attached
Please assist.
Tweakie.CNC
9,378
Super Kitty
Reply #3 on:
October 10, 2021, 05:03:37 AM »
The Mach3 breakout board you have shown in your earlier picture requires connection to your PC's Parallel Port. (n.b. The Parallel Port can only be used with 32 bit Operating systems).
inaxtor
6
Reply #4 on:
October 10, 2021, 05:27:30 AM »
there is a slot for usb.
Will usb to usb work?
And need to have 32 bit windows 10?
Does mach3 work on raspberry pi?
Tweakie.CNC
9,378
Super Kitty
Reply #5 on:
October 10, 2021, 06:10:42 AM »
The USB slot is just for a 5Volt power connection, the board needs the Parallel Port connection to work.
You need Win7 (or earlier) 32 bit OS.
Raspberry pi may well be capable but I doubt anyone has ever written a suitable driver.
inaxtor
6
Reply #6 on:
October 10, 2021, 01:41:31 PM »
Thank you so much. Really appreciate the assistance.
Last 2 questions please.
Will a parallel port to usb cable work for communications to computer?? (like attached)
And will I still need the 5v usb for power if I am using a parallel port cable?
Tweakie.CNC
9,378
Super Kitty
Reply #7 on:
October 11, 2021, 12:19:47 AM »
Unfortunately the USB / Parallel adapter cable will not work.
The Parallel cable will not provide 5 Volt power to the board so you will still use the USB cable.
inaxtor
6
Reply #8 on:
November 07, 2021, 06:33:44 AM »
The usb will provide the 5v power but the parallel will provide communications?
inaxtor
6
Reply #9 on:
November 07, 2021, 06:35:30 AM »
When trying to install mach3 support on windows xp I get an error:
"Unable to open output file"
Please assist.
Print
Pages:
1
Go Up
« previous
next »
