Hello Guest it is November 13, 2026, 11:55:34 AM
Author Topic: UC300-5LPT port problem  (Read 23451 times)
Offline Filou
  •  59 59
« on: October 04, 2021, 04:25:28 AM »
On a functional 4 axis rig, the UC300-USB was removed and replaced by a UC300-ETH, on a UC300-5LPT board.
UC300 plugin version v1.020, Mach 3 version X.066, running on Win 7, 64 bits.
One C11G BoB from Arturo (CNC4PC) connected on physical port 2 of UC300-5LPT. All pins assigned to "port 2" in Mach3 menu Config / PortPins: works flawlessly.
Connected second C11G on physical port 3 of UC300-5LPT, and assigned pins to "port 3" accordingly in Mach 3  No success.
One Wizard (thank you again Gerry) in this forum and the manufacturer of the UC300 board could not help.
The second C11G card is brand new, and wired in a similar way as the first one.
Sending a signal that makes its way through "port 2" in Mach 3 to "port 3" and connecting the original working C11G card to the appropriate physical port 3 on the LPT5 board fails. This seems to indicate that port 3 on the LPT cannot be addressed.
The alternative test, taking one pin along the "port 2" route and assigning it to "port 3" in Mach 3, makes this pin unavailable. Thus Mach 3 makes a difference between "port 2" and "port 3", regardless of the actual route beyond.
How can one port only on the LPT5 be defective ?   (cable tested to be OK)
Has anyone another idea ?
Enjoy your week, Philippe
PS: the monitoring window of the UC300 plugin reflects the exact observations made trough the whole controls chain.
Offline Filou
  •  59 59
Re: UC300-5LPT port problem
« Reply #1 on: October 05, 2021, 10:51:36 PM »
UP-DATE making a too long story somehow shorter:
On a UC300-5LPT board, using UC300ETH V1.020 plugins, ports 1,2 can be used. Port 3 remains inaccessible.
Result obtained by swapping working HW from port to port and re-configuring Mach3 accordingly.
I'm questioning a HW failure, since ports 1 and 2 on the LPT5 are operational. Enjoy your day.
Offline Filou
  •  59 59
« Reply #2 on: October 09, 2021, 02:27:15 AM »
ISSUE SOLVED.
The LPT5 unit works on port 1,2,3 whereas 4 and 5 were not tested. Plugin version 1.022
The smoking gun:  one of the C11G BoB cannot communicate with the motion controller, for unknown reasons.  The inputs of that board “see” status change and all LED indicators tell the user that the board appears functional and connected. There must be an internal broken link.  Enjoy your WE.
