Hello Guest it is November 18, 2026, 12:34:45 PM
Author Topic: Mach3 script conversion into macros for Mach4  (Read 15368 times)
Offline smurph
  •  1,575 1,575
Re: Mach3 script conversion into macros for Mach4
« Reply #10 on: September 30, 2021, 04:02:46 PM »
Setting up the tool table requires no scripting.  So why do you think you have to have a script or do scripting if you are using a manual tool change?  Unless I'm misunderstanding you.
Why don't you post the script that you wanted to "convert" to Mach 4 and let us see what is does.  It may be that Mach 4 doesn't even require a script where Mach 3 did.
Steve
« Reply #11 on: October 04, 2021, 12:54:51 AM »
hello I have already posted
view attachments of the first post of the post.
I love Mach4, I use it with great satisfaction on the lathe.
I built a new machine and wanted to use the Mill version.
or are there already solutions that I don't know?
I want to do part zero through a master instrument.
each subsequent tool must refer to the master through a previously stored value.
the new tool will update the part zero based on the new length.
