Hello Guest it is November 13, 2026, 03:47:42 PM
Author Topic: Auto ZTouch Probe tool crashes down rather than retracting  (Read 6546 times)
« on: September 26, 2021, 05:53:42 PM »
I'm using Mach 4 on an Avid CNC with their Plug and play electronics. I'm having an issue where the spindle goes down after touching the Z probe rather than up as expected. This doesn't happen every time but once it starts it continues until the software is restarted.
1 click on "auto Z touch Probe" button
2 spindle moves down slowly until it makes contact with the probe, probe signal shows active.
3 spindle moves DOWN rapidly 1" crashing into the probe, the normal operation would be for the spindle to move up by 1"
4 Y&X behave as expected
Thanks for any help
Re: Auto ZTouch Probe tool crashes down rather than retracting
« Reply #1 on: September 27, 2021, 11:26:59 PM »
Do you have the magnet connected with the collet? I've had the bit "crash" into the touch plate by not having the magnet connected to the collet
« Reply #2 on: September 28, 2021, 08:33:36 PM »
Error found: the tool table had data in it, this should only be used with automatic tool changers.
Solution: clear the data from the table
