Hello Guest it is November 13, 2026, 05:43:06 PM
Author Topic: TouchOff UI problem  (Read 6515 times)
TouchOff UI problem
« on: September 24, 2021, 01:18:49 PM »
Hello,
I have a CNC machine that I am controlling with Mach4 (build 4612) and ESS 275 plugin. When I use the Touchoff UI, it works fine for finding each axis separately. However, when I try to do the combined ones, like the front left corner for example, it finds Z then it moves to Y negative direction and then I get this error:
"ERROR: No contact with probe"
I attached the History file.
Any idea what might be causing this problem?
Thanks!
GOOMBA
Re: TouchOff UI problem
« Reply #1 on: September 24, 2021, 01:51:44 PM »
Try this with logging running and then upload that file and we'll have a better idea :)
« Reply #2 on: September 24, 2021, 02:37:34 PM »
Here is the log file. Thanks!
