Hello Guest it is November 19, 2026, 02:48:18 AM
Author Topic: Circles  (Read 17499 times)
Circles
« on: September 16, 2021, 06:56:40 AM »
Hello! I'm having a problem that i don't know where it comes from, i using partmaster cad and cam to do my g code and used many post processor to see if the problem is the ppr but after 5 tests and test my program manually writed i just don't know what is the problem, can anyone help me?
The problem is i want to do some radius but my program keeps making circles... sorry for my english, it's not my motherlang
  •  9,378 9,378
Re: Circles
« Reply #1 on: September 16, 2021, 07:03:06 AM »
In Config. / General Config.  change the IJ Mode then regen. the toolpath window.
Re: Circles
« Reply #2 on: September 16, 2021, 07:14:17 AM »
I do that, changed from absolute and incremental but nothing changes, i upload what i want to do with that program
« Last Edit: September 16, 2021, 07:16:00 AM by Nbzinhoxxd »
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Circles
« Reply #3 on: September 16, 2021, 04:50:00 PM »
Check this setting in Ports & Pins
Re: Circles
« Reply #4 on: September 17, 2021, 06:01:28 AM »
Ok, i changed the setting to diameter and get no differences but if i turn off reverse arc option, i'm getting this in my program:
But i want to do the arc to the other side but idk how to setup this to get what i want.
  •  2,785 2,785
Re: Circles
« Reply #5 on: September 17, 2021, 03:16:38 PM »
I don't think its a Mach3/4 fault.
My Fanuc 18i controlled lathe shows the same problem.
What did you use to create the code.  A Fanuc 6 post processor will get you runnable code on most CAM systems.
Standard 2 axis lathes should work in diameter mode and use incremental I and K or R in G02 and G03 commands.
Re: Circles
« Reply #6 on: September 17, 2021, 06:25:41 PM »
Try swapping out your g02's and g03's. I edited my post processor to swap the two commands and everything is working for me now. It started for me when I upgraded from mach3 to mach4.
