Hello Guest it is November 13, 2026, 04:15:57 PM
Author Topic: Ease-in and ease-out spindle on M3 and M5?  (Read 7869 times)
Offline Azalin
  •  191 191
« on: September 12, 2021, 03:47:22 PM »
My spindle motor is an AC servo and it is driven with 0-10v analog. Currently the servo does hard start on M3 and hard stop on M5. Is there a way to setup Mach4 to increase the analog signal from 0 to the desired speed like 500ms so it'll kinda soft start and vice versa?
Offline Azalin
  •  191 191
Re: Ease-in and ease-out spindle on M3 and M5?
« Reply #1 on: September 12, 2021, 04:28:24 PM »
I forgot to mention that my control board is an M16D with PoKeys 57E.
« Reply #2 on: September 13, 2021, 01:52:39 AM »
That should be easy to do it from your servo drive settings, check the manual. I don't think that you can do it from Mach4.
Offline Azalin
  •  191 191
« Reply #3 on: September 13, 2021, 03:34:05 AM »
After I read your post I searched for parameters and found ADCRiseTime and ADCFallTime. Setting these to 500ms did the trick.
Thanks.
« Reply #4 on: September 13, 2021, 04:05:42 AM »
Thanks.
You are welcome, glad that you solve it.
