Hello Guest it is November 19, 2026, 03:00:16 AM
Author Topic: MACH 3 TURN has circles instead of lines  (Read 16874 times)
« on: August 31, 2021, 09:13:38 PM »
Hi, here's the thing, I'm doing some homework, so basically I have to make a figure like this with a turn, but at mastercamx5 looks fine, but when I transport the G-Code from the app to MACH 3 turn I doesn't look like it has to, I mean this is the correct piece at mastercam x5 and the next one is how actually looks at MACH 3, this is my code, please if you see any mistake correct me.
(MATERIAL - PLASTIC MM - ACETAL)
G21
(TOOL - 1 OFFSET - 1)
(STARTURN CILINDRADO  INSERT - DCMT 11 T3 04)
( OPERACION DE CAREADO )
G91 G28 X0. Z0
G90
M6 T0101
G18
G97 S2046 M03
G04 P30
G0 G54 X29.4 Z.5
G94 G1 X-.8 F346.
G0 Z2.5
X29.4
Z0.
G1 X-.8
G0 Z2.
( OPERACION CILINDRADO O DESBASTE )
X24.575
Z3.2
G1 Z2.2 F364.
Z-46.266
X25.389 Z-49.321
G18 G3 X25.4 Z-49.4 I-.595 K-.079
G1 Z-54.8
X25.8
X27.214 Z-54.093
G0 Z3.2
X23.35
G1 Z2.2
Z-20.729
G3 X23.4 Z-20.9 I-.575 K-.171
G1 Z-22.9
Z-41.86
X24.975 Z-47.766
X26.957 Z-47.634
G0 Z3.2
X22.125
G1 Z2.2
Z-18.89
X23.338 Z-20.71
G3 X23.4 Z-20.9 I-.569 K-.189
G1 X25.4
G0 Z3.2
X20.9
G1 Z2.2
Z-8.413
G3 X21.4 Z-8.9 I-.35 K-.488
G1 Z-12.9
Z-17.803
X22.525 Z-19.49
X24.422 Z-19.174
G0 Z3.2
X19.675
G1 Z2.2
Z-8.275
G2 X20.2 Z-8.3 I.262 K1.375
G3 X21.3 Z-8.66 K-.6
G1 X23.133 Z-8.261
G0 Z3.2
X18.45
G1 Z2.2
Z-7.993
G2 X20.075 Z-8.299 I.875 K1.093
G1 X20.164 Z-7.3
G0 Z3.2
X17.225
G1 Z2.2
Z-5.088
G3 X17.4 Z-5.4 I-.513 K-.312
G1 Z-6.9
G2 X18.85 Z-8.127 I1.4
G1 X19.814 Z-7.25
G0 Z3.2
X16.
G1 Z2.2
Z-4.796
G2 X16.2 Z-4.8 I.1 K1.397
G3 X17.4 Z-5.4 K-.6
G1 Z-6.9
G2 X17.625 Z-7.45 I1.4
G1 X19.464 Z-7.057
G0 Z3.2
X14.775
G1 Z2.2
Z-4.605
G2 X16.2 Z-4.8 I.712 K1.205
G3 X16.4 Z-4.809 K-.6
G1 X16.733 Z-3.822
G0 Z3.2
X13.55
G1 Z2.2
Z-3.852
G2 X15.175 Z-4.703 I1.325 K.452
G1 X15.907 Z-3.772
G0 Z3.2
X12.325
G1 Z2.2
Z-1.508
G3 X13.4 Z-3.4 I-3.062 K-1.892
G2 X13.95 Z-4.234 I1.4
G1 X15.557 Z-3.638
G0 Z3.2
X11.1
G1 Z2.2
Z-.762
G3 X12.725 Z-1.878 I-2.45 K-2.638
G1 X14.538 Z-1.455
G0 Z3.2
X9.875
G1 Z2.2
Z-.304
G3 X11.5 Z-.964 I-1.837 K-3.095
G1 X12.972 Z-.286
G0 Z3.2
X8.65
G1 Z2.2
Z-.015
G3 X10.275 Z-.432 I-1.225 K-3.385
G1 X11.407 Z.392
G0 X21.72
X22.814
Z-12.193
G1 X21.4 Z-12.9
G3 X21.25 Z-13.191 I-.6
G1 X20.156 Z-14.178
Z-15.3
X20.2
G3 X21.4 Z-15.9 K-.6
G1 Z-17.803
X21.8 Z-18.403
X23.697 Z-18.086
G0 Z-13.541
X22.478
G1 X20.556 Z-13.817
X18.911 Z-15.3
X20.2
G3 X20.556 Z-15.327 K-.6
G1 X21.148 Z-14.372
G0 X23.72
X24.814
Z-22.193
G1 X23.4 Z-22.9
G3 X23.25 Z-23.191 I-.6
G1 X22.4 Z-23.957
Z-25.308
G3 X23.4 Z-25.9 I-.1 K-.591
G1 X25.4
G0 Z-23.321
X24.723
G1 X22.8 Z-23.596
X21.4 Z-24.859
Z-25.3
X22.2
G3 X22.8 Z-25.381 K-.6
G1 X23.8 Z-24.514
G0 X24.12
X24.814
Z-38.193
G1 X23.4 Z-38.9
G3 X23.25 Z-39.191 I-.6
G1 X22.4 Z-39.957
Z-41.308
G3 X23.389 Z-41.821 I-.1 K-.591
G1 X23.8 Z-43.36
X25.782 Z-43.228
G0 Z-39.321
X24.723
G1 X22.8 Z-39.596
X21.4 Z-40.859
Z-41.3
X22.2
G3 X22.8 Z-41.38 K-.6
G1 X23.8 Z-40.514
( AFINADO )
G18
G97 S2300
G0 Z2.
X6.2
G1 Z0. F246.
G18 G3 X13. Z-3.4 K-3.4
G2 X16.2 Z-5. I1.6
G1 X17.
Z-6.9
G2 X20.2 Z-8.5 I1.6
G1 X21.
Z-12.9
Z-15.9
Z-17.835
X23. Z-20.835
Z-22.9
Z-25.9
Z-38.9
Z-41.873
X25. Z-49.373
Z-55.
X27.828 Z-53.586
G91 G28 X0. Z0. M05
G90
M01
(TOOL - 3 OFFSET - 3)
(OBTENCION GARGANTAS  INSERT - N151.2-200-5F-MOD)
( OBTENCION DE GARGANTAS )
G0 T0303
G18
G97 S700 M03
G04 P30
G0 G54 X25. Z-15.5
G1 X17. F120.
G0 X25.
Z-14.5
G1 X17.
X17.2 Z-14.6
G0 X25.
X27.
Z-25.5
G1 X21.
G0 X27.
Z-24.5
G1 X21.
X21.2 Z-24.6
G0 X27.
Z-41.5
G1 X21.
G0 X27.
Z-40.5
G1 X21.
X21.2 Z-40.6
G0 X27.
X33.
Z-55.
G1 X29.
X-.4
X3.6
G0 X29.
G91 G28 X0. Z0. M05
G90
M30
  •  9,378 9,378
Re: MACH 3 TURN has circles instead of lines
« Reply #1 on: August 31, 2021, 11:29:38 PM »
In Config. / General Config. change the IJ Mode state then regen. the toolpath.
In your Gcode, line 204 'G0T0303' is incorrect.
