Hello Guest it is November 13, 2026, 10:43:42 PM
Author Topic: Mach4 Enable/Disable Script  (Read 7552 times)
« on: August 27, 2021, 08:04:03 AM »
Hey Everyone,
I would like 2 physical button 1 to enable and the other to disable. These would replicated the onscreen "Enable" and "Disable" button in mach4. Is there a script to assign one of the inputs in Mach 4 to be an "Enable" button?
Peter
Re: Mach4 Enable/Disable Script
« Reply #1 on: August 27, 2021, 09:06:54 AM »
I use one button to toggle enable on the control panels here in the shop.
Just put the code in the signal library in the screen load script.
I modified my code so one input will enable mach and the other will disable mach.
[mc.ISIG_INPUT6] = function (state)
    if (state == 1) then
       local inst = mc.mcGetInstance();
        mc.mcCntlEnable(inst,1)
   end
end,
[mc.ISIG_INPUT7] = function (state)
        mc.mcCntlEnable(inst,0)
   end
end,
Chad Byrd
« Reply #2 on: August 27, 2021, 10:57:04 AM »
   end
end,
   end
end,
Thanks for you help this worked.
Do you know if its possible to do the same for M07(mist on) M08(coolant on) M09(off)?
Peter
« Reply #3 on: August 27, 2021, 01:20:45 PM »
Never mind I found a script for it.
Peter
« Reply #4 on: August 27, 2021, 03:13:46 PM »
There is a lot you can do with the signal library with inputs. I use the same button to toggle enable, spindle, coolant, and the keyboard. I also have a button for reset, cycle start, and feedhold.
Chad Byrd
