Hello Guest it is November 13, 2026, 03:14:30 PM
Author Topic: Tool path window in lathe  (Read 9843 times)
« on: August 22, 2021, 03:43:03 PM »
I load a gcode file in lathe and the tool path is so small it is about one pixel. I click regen toolpath and nothing changes. I would have thought if I regen the toolpath would be displayed on the XZ plane at a zoom where it can be seen. Are there any known issues that would make this happen. Maybe I need to change the display settings for my video card?
Re: Tool path window in lathe
« Reply #1 on: August 22, 2021, 05:52:59 PM »
If you look at the circle in the tool path window the little white dot in the circle is my tool path. Regen sets it back to this. If i use the mouse to turn zoom and twist it for a few minutes I can almost see the tool paths.
« Reply #2 on: August 28, 2021, 10:45:17 AM »
Tool paths are displaying better.
Is there a setting or an edit to keep the tool paths from moving in the window and have the cutter position move. The tool paths moving like that gives me motion sickness.
« Last Edit: August 28, 2021, 10:48:12 AM by stevehuck »
Offline smurph
  •  1,575 1,575
« Reply #3 on: August 29, 2021, 03:52:02 PM »
You have to edit the screen set and change the tool path's properties.  The "Follow Mode" property, to be specific.
Steve
« Last Edit: August 29, 2021, 03:56:22 PM by smurph »
« Reply #4 on: September 05, 2021, 03:54:06 PM »
That did the trick! Thank You
« Reply #5 on: September 05, 2021, 03:56:32 PM »
I guess that would actually be Mach-Motion sickness!! Haha
Offline smurph
  •  1,575 1,575
« Reply #6 on: September 07, 2021, 03:22:16 PM »
Ba da bum!
I think you just may be as corny as I am.  :)
