Hello Guest it is October 21, 2026, 08:16:10 PM
Author Topic: About Dereference All Axes  (Read 6504 times)
« on: August 11, 2021, 12:26:22 AM »
Hello everyone.
Please tell me the meaning of Dereference All Axes with the red arrow in the photo.
I am "Mach4 CNC Controller
Software Installation and
I saw "Configuration Guide", but there seems to be no explanation.
Please tell us in an easy-to-understand manner.
Offline Bill_O
  •  615 615
Re: About Dereference All Axes
« Reply #1 on: August 11, 2021, 09:00:41 AM »
Dereference All Axis removes the machine home position from Mach.
If you have home switches and you Reference the axis Mach has a starting point.
This starting point can then use the Soft Limits and other functions.
If you have your machine set to Reference in place then when you Reference an axis it is just where it is currently sitting.
Hope this helps
« Reply #2 on: August 11, 2021, 04:12:34 PM »
Answer Hello Bill_O.
I haven't used mach4 on a milling machine yet.
When you're done, give it a try.
Thank you very much.
