Hello Guest it is November 13, 2026, 12:07:00 PM
Author Topic: Need help  (Read 24126 times)
Need help
« on: August 08, 2021, 07:34:49 PM »
 I'm a total newbie to cnc and need some help or at  least a point in the right direction. I have a Zenbot 4848 with a Gecko 540 controller. My problem is that my Y axis and A axis slave are fighting each other trying to twist my gantry. If I unplug the A axis it operates fine. The A axis is operating in reverse. Did I miss something in the initial setup ?
  •  9,377 9,377
Re: Need help
« Reply #1 on: August 08, 2021, 11:21:16 PM »
In Config. / Ports & Pins / Motor Outputs - change the Dir Low Active state for your A axis then Apply the change.
Re: Need help
« Reply #2 on: August 09, 2021, 05:34:44 PM »
 Thanks. That did the trick.  Now my z axis is running in reverse of what it should be doing. Still running tests before I attempt my first cut. Any advice would be helpful. Thanks
Re: Need help
« Reply #3 on: August 09, 2021, 05:58:14 PM »
 Got it ll figured out... It was the nut behind the keyboard... Forgot to toggle the reverse in the homing settings.
  •  9,377 9,377
Re: Need help
« Reply #4 on: August 10, 2021, 12:04:25 AM »
 :D :D :D
