Hello Guest it is November 18, 2026, 11:43:33 AM
Author Topic: Need help triggering feedhold with a driver alarm - Mach 4  (Read 9620 times)
« on: August 02, 2021, 07:45:56 PM »
I have hybrid stepper motors on my plasma table and I would like the alarm function to trigger a feed hold in Mach 4.  I have tried numerous different times to write the code myself (more like copying others code) but I can't get it to work.  Right now I have the code where it reads the pin when the state changes and it sends an error message but I can't get it to trigger a feed hold no matter what I try.  Any help would be appreciated.
Code so far:
[mc.ISIG_INPUT0] = function (state)       -- X Axis
        mc.mcCntlSetLastError(inst, "X Axis driver ALARM - STOPPING")
    end,
Thanks!
Offline DazTheGas
  •  778 778
  • DazTheGas
Re: Need help triggering feedhold with a driver alarm - Mach 4
« Reply #1 on: August 03, 2021, 04:09:20 AM »
Try using mc.mcCntlFeedHold(inst) after you have set your error
DazTheGas
« Reply #2 on: August 03, 2021, 11:32:59 AM »
Code: [Select]
-- Axis driver Alarms
-- Each motor driver has an alarm line that goes high
-- if ********* goes south
-- Stop machine and recover using external reset switches
    [mc.ISIG_INPUT9] = function (state)       -- X Axis
eStop()
    end,
    [mc.ISIG_INPUT10] = function (state)       -- Z axis
        mc.mcCntlSetLastError(inst, "Z Axis driver ALARM - STOPPING")
eStop()
    end,
I wouldn't feed hold - I'd eStop.
Driver alarm means "I tried to get to the commanded move point but didn't get there" so you have lost positioning and something is very wrong.
That's a "shut everything off NOW" situation.
« Reply #3 on: August 03, 2021, 02:43:04 PM »
i think PMC can be the best way
« Reply #4 on: August 03, 2021, 08:14:04 PM »
DazTheGas
This worked perfectly, thanks!
« Reply #5 on: August 03, 2021, 08:18:22 PM »
[/quote]
I thought about estop but since it's a plasma table I'm not too worried about a few lost steps, I wanted to be able to start back up if things were still close.  I have limit switches on both sides of all the axis and a magnetic torch head so I doubt I could crash it too bad.  I'll probably eat those words one day but for now it makes sense in my head.
