Hello Guest it is September 05, 2026, 03:20:59 AM
Author Topic: Jog Rate lost each shutdown  (Read 13515 times)
« on: July 29, 2021, 10:51:01 PM »
I asked about this a while back, but I don't think I got any replies.  Mach 4 doesn't save my current jog rate.  I can manually change it in the ini file and that works.  Am I doing something wrong?
Not a big deal, but just something I'd like to fix if possible.
I am using the Avid screenset.  Mach 4.  Nothing unique.
Thanks for the help.
Tony
Re: Jog Rate lost each shutdown
« Reply #1 on: July 31, 2021, 03:41:28 AM »
I think it depends on how Avid have set this up.. When you update the ini file manually which parameter are you changing? If you can upload the screenset I could have a look at it. Which mach4 build are using also?
« Reply #2 on: July 31, 2021, 03:54:48 PM »
I am using Mach 4 Version 4.2.0.43222    Build 4322.  The profile is AvidCNC.
In the machine.ini file, there is a variable on a line by itself:
JogRate=20.000000
Whatever I set that value to using Notepad, loads when I start Mach 4.   BUt if I change it in Mach 4, it is not ever saved.  I know it had to have saved a value at one point because it was set to something like 3 (not sure why).
Also, I am using an ESS  (WARP 9 - Build 253).
Thanks for the help!
Tony
« Reply #3 on: August 01, 2021, 04:46:11 AM »
you may be familiar with the ScreenLoad script, which as described populates all the screen elements
but what you may not be familiar with is the ScreenUnLoad script......it has code that saves all the pertinent data
for the next session.  Why not include an instruction to save the jog rate at the moment of shutdown?.
« Reply #4 on: August 02, 2021, 09:03:25 PM »
This is from the unload script...
--Save Jog Rate % to .ini
local valJogRate = scr.GetProperty("droJogRate", "Value")
mc.mcProfileWriteString(inst, "Preferences", "JogRate", valJogRate)
Doesn't seem to work though.
« Last Edit: August 02, 2021, 09:05:58 PM by TonyMemphis »
« Reply #5 on: August 04, 2021, 04:26:08 AM »
 this is the code snippet that is the 'OnModify' event behavior of JogRate%:
Code: [Select]
local val = scr.GetProperty("droJogRate", "Value")
mc.mcProfileWriteString(inst, "PersistentDROs", "droJogRate", string.format (val)) --Create a register and write the machine coordinates to it
Which suggests that it is a string that must be written to the .ini file.
Try it and see.
« Reply #6 on: August 04, 2021, 05:39:54 PM »
Well, it looks like that is what it is trying to do.  The Value it gets is a string I think.
I deleted the JogRate line from the machine.ini file, then ran Mach4.  When I exited, the jog rate was saved.  But the next time I changed it and exited, it was not.
Thanks for helping!  I appreciate it.  I may just drop a note to the AVID folks.
Tony
Offline DazTheGas
  •  778 778
  • DazTheGas
« Reply #7 on: August 08, 2021, 02:29:42 PM »
Like Craig suggested putting it in the shutdown script is good, but one extra thing is in your screen load script or first run of the PLC script is to use 'mc.mcJogSetRate' as a way of setting the jog rate but you will have to set this for all axis xyz etc.
DazTheGas
« Reply #8 on: August 08, 2021, 04:21:44 PM »
Well, I must not be masking this clear.  Sorry!  But the AVID screen unload script DOES have code that is supposed to save the current jog rate.  But it doesn't.  The only time I can make it work is if I edit the machine.ini file with Notepad and remove the jog rate line.  After that, the rate is saved once but never again.
Tony
Code: [Select]
--Screen unload
if (Tframe ~= nil) then -- touch plate frame
Tframe:Close()
-- Tframe:Destroy()
end
if (ASframe ~= nil) then -- touch plate advanced settings frame
ASframe:Close()
-- ASframe:Destroy()
end
-- check modified state of config files
pf.CheckAllConfigFiles()
« Reply #9 on: August 10, 2021, 11:42:53 AM »
Well, after a lot of searching and reading, etc., I still can't make it work.  I can use mc.mcJogGetRate for a single axis and that works fine,  The problem seems to be the screen call doesn't ever return anything.  I tried getting the Values and Labels from numerous things on the screen and I never get anything but a nil or a "".
I am using the AVID setup and my Mach 4 version is 4.2.0.4322.
Any ideas?
This is what is NOT working:   local valJogRate = scr.GetProperty("droJogRate", "Value")
Tony
