Hello Guest it is November 18, 2026, 12:02:46 PM
Author Topic: Mach4 Homing & Limits  (Read 5942 times)
« on: July 23, 2021, 02:31:31 PM »
Ok. I need a little help. I've watched the video:
https://www.youtube.com/watch?v=IXuuGRACU1I&t=232s
My machine is running and will cut material. However, I want the satisfaction of turning on my machine and watching it find the home switches I have installed. LOL
I do a reference and it will say that it they are referenced and then it doesn't home the machine. Attached are my pictures of my setup. I don't know if I am doing something wrong or just have a setting in the software incorrect.
I also have mach3 and the homing sequence works on that. But I'd like to use Mach4 exclusively and would like to see it home itself like it does in mach3.
I'll add more pictures if needed. Any help is appreciated.
Here is my hardware:
Dell Lenovo Laptop
UC400ETH Motion Controller
ST-V3 Breakout board
Thank you for your help in advance.
Re: Mach4 Homing & Limits
« Reply #1 on: July 24, 2021, 11:07:48 AM »
The reference sequence start if the x home e.t.c is enabled and maped, your input1 e.t.c is not your home input.
If your controller plugin do something that i am not aware forgive me :), i think you need to remove mapping of input 1-2-3 and map with the pins of your controller to x home, y home, z home e.t.c.
