Hello Guest it is November 13, 2026, 12:39:16 PM
Author Topic: 1 axis linear actuator  (Read 23976 times)
« on: July 22, 2021, 11:09:09 AM »
I'm making a single axis linear actuator to my mitre saw and I need help with how I configure Mach3 to move the X axis by just entering the desired length in a DRO. I'm OK with designing the screen-set (draft image attached) but unsure how to actually perform the simple 'move' of the axis.
Basically, is there a simple way to perform an MDI input......for example "G0 X250", but only using a DRO?  I've seen exactly what I require done by someone but they don't say how they achieved it in Mach3.
Any assistance would be greatly appreciated.
Re: 1 axis linear actuator
« Reply #1 on: July 23, 2021, 04:30:08 AM »
Hi krsykes23
you could try this using MachScreen:
Set function Code “Execute Basic Script” for your buttons and add to “execution code” of every button:
Button “GO”
PosX = GetOEMDRO(800)
Code("F100 G0” & PosX)
While (IsMoving())
Sleep(100)
Wend
“Button Arrow Left”
PosX = PosX – 1.0
Code("G0 X" & PosX)
While(IsMoving())
Sleep(100)
Wend
“Button Arrow Right”
PosX = PosX + 1.0
Code("G0 X" & PosX)
While(IsMoving())
Sleep(100)
Wend
the first example sets an additional feedrate .
Klaus
The brain isn't a soap, it doesn't shrink when used.
« Reply #2 on: July 23, 2021, 04:53:28 AM »
Many thanks Klaus,
I'll give this a try!
Keith
Offline TPS
  •  2,627 2,627
« Reply #3 on: July 23, 2021, 06:16:39 AM »
