Hello
Guest
it is
October 24, 2026, 12:44:38 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Calibration Issue
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Calibration Issue (Read 9004 times)
phando
40
Calibration Issue
on:
July 14, 2021, 07:18:51 PM »
Hello,
I am finishing my my migration from Mach3 to Mach4. I just got done with calibrating my axis (without backlash) and noticed an issue. My calibration was done over 1". The mill is moving more accurately than I was hoping. The issue is when I move less than 1" there is a progressive error (not moving far enough). Once the machine gets to 1" it is perfect. I am unsure if the error continues on the other side of 1" but if it does, I would imagine the machine will be moving too far.
Anyone else run into this?
Logged
Cbyrdtopper
985
Re: Calibration Issue
Reply #1 on:
July 15, 2021, 10:23:46 AM »
If you have the ability, calibrate it to a longer length. The longer, the more accurate. I use a dial indicator to calibrate axis on our machines, but I always check to be sure it moves further accurately.
Logged
Chad Byrd
phando
40
Reply #2 on:
July 15, 2021, 11:56:04 AM »
@Cbyrdtopper, thank you for the response. Using a ruler I was able to see that the mill is off by 1/16" over 20". I think where I may have been going wrong is that I am not preloading the screw in the right direction before taking my calibration measurement. Today I will try to move the screw 0.05 (in the measurement direction) to zero then measure my 1" with the micrometer. Maybe moving back and forth between 0 and 1" was adding backlash to my calibration. Additionally I will look into taking the backlash out using the screw adjustments.
Last Edit: July 15, 2021, 12:00:55 PM by phando
Logged
Cbyrdtopper
985
Reply #3 on:
July 15, 2021, 12:03:02 PM »
Getting the backlash out mechanically is absolutely the best way to do it. Removing backlash in the software is just like a bandaid... it just masks the problem.
If you have a good quality ruler, use that for your calibration. Get an extremely fine point tool in the spindle and move it from 0 to 20 and try that. It should get you pretty close across 20" of travel.
Logged
Chad Byrd
phando
40
Reply #4 on:
July 15, 2021, 01:31:59 PM »
I am out of the woods, thank you. This is the most accurately I have ever calibrated a machine. Super stoked!
Logged
RecceDG
135
Reply #5 on:
July 16, 2021, 10:15:20 AM »
What is also instructive is placing a dial indicator - a sensitive one, like a tenths indicator - and jogging in 0.001" increments. It demonstrates backlash and other weirdness immediately
Logged
Print
Pages:
1
Go Up
« previous
next »
