Hello Guest it is November 13, 2026, 09:41:11 AM
Author Topic: where are the tool offset tables stored  (Read 28603 times)
« on: July 14, 2021, 04:36:17 AM »
Hi
does anyone know where the tool and work offset tables are stored?
in mach 3 please
Colin
« Last Edit: July 14, 2021, 06:36:15 AM by Tweakie.CNC »
  •  9,377 9,377
Re: where are the tool offset tables stored
« Reply #1 on: July 14, 2021, 06:45:31 AM »
Hi Colin,
Config. Fixtures... are where the Work Offsets are defined.
Config. Tool Table... is where the Tool information is defined.
The data entered is then stored in the <profile> .xml file when Mach3 is closed.
« Reply #2 on: July 14, 2021, 08:54:29 AM »
many thanks for your prompt reply
can I copy the tool tables so that I can update or enter them on my main computer
  •  9,377 9,377
« Reply #3 on: July 14, 2021, 08:59:25 AM »
I think they can only be updated within a running Mach3.
Offline TPS
  •  2,627 2,627
« Reply #5 on: August 02, 2021, 02:37:22 AM »
I've used both the import and export macros in that link successfully.
