Hello Guest it is November 13, 2026, 04:46:25 PM
Author Topic: Pokeys 57e and Mach4 mill spindle encoder SRO question  (Read 49750 times)
Re: Pokeys 57e and Mach4 mill spindle encoder SRO question
« Reply #10 on: July 19, 2021, 04:22:59 PM »
Can you rigid  tap ?
Offline Azalin
  •  191 191
« Reply #11 on: July 19, 2021, 04:24:43 PM »
Machine is still unfinished so I don't know yet :)
« Reply #12 on: July 16, 2022, 03:33:49 PM »
My problem solved as follows:
As I described everything was good. In diagnostics screen all inputs and outputs worked fine. The reason Mach4 didn't display the actual RPM was just a screen set misconfiguration. I clicked the "Edit Screen" menu item then selected the "Spindle RPM" text field. Then in the "DRO Code" property I just selected "Spindle True RPM" then save.
After that Mach4 started to display the true RPM that comes from the encoder.
Solved this by an accident took my 2 weeks. Dang!
Your 2 week accident saved me a ton of time.  I had already spent most of a day pulling my hair out over this.  Thanks for posting your solution.  Worked like a champ!
Offline Azalin
  •  191 191
« Reply #13 on: July 16, 2022, 03:36:06 PM »
I'm happy to help.
« Reply #14 on: July 21, 2022, 11:27:16 AM »
Good job.
« Last Edit: July 21, 2022, 11:28:53 AM by gabedrummin »
