Hello Guest it is October 24, 2026, 08:44:01 PM
Author Topic: How to check when a module is closed or done running  (Read 5287 times)
« on: July 10, 2021, 10:29:32 AM »
Hi Everyone!
I have a module that i wanted to modify but it can't since it is a compiled Lau script. The developer of the module won't give me the uncompiled script.
To use this script I need to cancel tool offsets prior which is easy to do but I also need to turn it back on when the module end or is closed. This module opens in a pop up window. I need turn on G43 for a current tool when the window is closed with by the module itself or if someone press the close button. Can this be done in Mach4?
I had no luck finding a close event signal that I can use with in the signal script. I might be looking in the wrong place trying to make this work.
Kenny
