Hello Guest it is October 20, 2026, 03:01:03 PM
Author Topic: x axis reverse problem  (Read 23273 times)
« on: July 08, 2021, 07:53:56 AM »
Running mach3 on prt 96 shopbot cnc
my motors are slaved running off one Gecko drive.
motors started running in opposite direction.
how do i reverse the direction of one motor?
thanks for your help. Paul
  •  9,374 9,374
Re: x axis reverse problem
« Reply #1 on: July 08, 2021, 09:28:38 AM »
Transpose the connection of the two wires on just one phase of one steppr motor connection.
« Reply #2 on: July 08, 2021, 12:32:34 PM »
Hi Tweakie.
Thanks for your reply   sorry about this but i poster the incorrect information.
each stepper motor is running on its  independent  gecko drive
both gecko drives  are connected to a PMDX -122    to the same connector J3
the cnc  have been running for the past 7 years  with no problem.
so not sure how do i go about solving this problem.
both motors are turning  just one need reversing .
does your reply still stand?     if so can this be done off the gecko drive?
  •  9,374 9,374
« Reply #3 on: July 08, 2021, 11:50:47 PM »
Yes it still applies, just swap the connection of the two leads connected to one of the phases (eg. A - +A) at the gecko.
