Hello Guest it is October 24, 2026, 08:56:47 AM
Author Topic: Ignore Tool Changes setting?  (Read 14696 times)
« on: July 06, 2021, 05:41:42 PM »
Mach4 4.2.0.4612
ESS build 275
Hi
There used to be a setting in configurations: Ignore Tool Changes.
I cant find it anymore.
Can someone advise?
TIA.
Re: Ignore Tool Changes setting?
« Reply #1 on: July 08, 2021, 11:01:53 AM »
Maybe someone else knows if there is a better way but I think you need to modify your m6.mcs so that it does nothing but return.
HTH
RT
Offline gorf23
  •  190 190
« Reply #2 on: July 08, 2021, 02:55:55 PM »
I think if you go into mach4 config-tools and check T on M6 line is next tool it will not stop and ask for a tool change..
« Reply #3 on: July 11, 2021, 06:04:34 PM »
Thanks for the replies.
So the Ignore Tool Change setting no longer exists?
I did try "T on M6 line " setting but it didn't make any difference.
However on some other old files which worked as expected previously, the original setting did successfully pass the tool change code, but hung a little later as per my other thread:
https://www.machsupport.com/forum/index.php?topic=44993.0
Is this some configuration issue that I need to address in the new version, or should I be submitting a bug report??
Offline Stuart
  •  311 311
« Reply #4 on: July 12, 2021, 05:08:52 AM »
if you do not select a tool in your CAM setting in aspire what happens ?
would it be possible to edit the Post Processor file to not output a M6 command then Mach4 would have nothing to do
« Reply #5 on: July 12, 2021, 06:49:19 AM »
What CAM you use, why not just ignore the tool changes from post processor?
« Reply #6 on: July 12, 2021, 08:16:02 AM »
I may be wrong.... but I don't think Mach4 ever had that option; mach3 did.
If you wish to use the tool change at a later date, then you should do what I did on a machine; I added a button that toggled an input to either use the ATC or not.
If the input was active the machine would just sit and wait for a manual tool change with a message box popped up, if it was not active, it ran through the automatic tool change sequence.
You could do the same thing, where if you have your own "Ignore tool change" button active then the machine would just run to the end of the m6 macro and ignore everything in the middle.
Chad Byrd
« Reply #7 on: July 12, 2021, 11:32:55 PM »
I'm not sure what the reference to aspire means here.
I'm using SheetCam, and according to them Tool Change code is written into all their Router posts.
I did try deleting out the Tool Change G code from files in question.
I also tried making a copy of the Post processor, deleting out the Tool Change macro and re-running the file.
In each case the cycle froze immediately after where the tool change code was. IE as per my other posting.
The suggestion to create a custom toggle sounds good, but I think is beyond me at the moment.
In any case the files which are now freezing worked perfectly in the previous version of Mach4 I was on.
So; it seems either something has been changed in Mach4 that I need to address, or there is a bug.
Is there alternate explanation/s why files which previously ran would stop running after an update?
regards,
N.
« Reply #8 on: July 13, 2021, 12:06:52 AM »
I use Sheetcam with same vs of Mach4 and no problem with tool changes, but in files i don't make tool change..
Panos
« Reply #9 on: July 16, 2021, 05:01:15 PM »
I had exactly the same problem as you regarding your other posting.
With me it was caused by having the "Wait On Spindle To Stabilize "xx " Percent" Box checked (Under Mach4 Spindle Configuration Tab).
At the time, I didn't have any Spindle feedback to Mach via the ESS, so Mach just sat there waiting for a signal that was never going to appear.
Nick.
« Last Edit: July 16, 2021, 05:03:30 PM by nick952 »
