Hello Guest it is October 24, 2026, 10:18:41 PM
Author Topic: Carving comes out 4 inches off center  (Read 6747 times)
« on: July 01, 2021, 03:41:12 PM »
I'm putting this problem in Art Soft because I don't know where the problem originates from. I'm using the center of the project as the center point and the carving starts out well but then the spindle shifts about 4 inches off center and continues. If I allow it to run its course it does the rest of the carving 4 inches off center. I cannot tell where the problem is. I'm using mach4 ver. 4.2.0.3461 the machine is home built and I have been using it for about 4 years.
Thank you in advance
Offline Bill_O
  •  615 615
Re: Carving comes out 4 inches off center
« Reply #1 on: July 02, 2021, 09:26:04 AM »
Are you using stepper motors?
« Reply #2 on: July 02, 2021, 10:16:03 AM »
Yes. The off center is in the Y axis.
Offline Bill_O
  •  615 615
« Reply #3 on: July 02, 2021, 11:45:50 AM »
It wounds to me like either the motor is stalling or something is slipping.
Try slowing the move speed and make sure the screw or gear that moves it is tight.
« Reply #4 on: July 02, 2021, 03:09:20 PM »
Oh dear. Before I read your post I decided to recenter the carving and run the rough cut again, which I did and it cut as it should. When it finished I changed the bit and ran the finishing tool path and it started out well then gradually began cutting deeper and deeper until it cut all the way through the material. I just checked all the ball screws and they are tight. I'll try slowing the motor speeds.
