Hello Guest it is October 20, 2026, 08:38:04 PM
Author Topic: Z homing not retracting  (Read 22059 times)
« on: July 01, 2021, 03:07:57 PM »
OK I am confused and hope someone can help. I have now disabled the limit switch as an estop and have it as a homing sw only. All other axis work as they should. The Z axis runs to the Pos home switch, triggers the switch and then stops. It will not retract off of the switch. Any reason for this??
I am under the impression there is no settings in Mach for retracting, it just moves until the switch opens again then stops??
Todd
Offline TPS
  •  2,627 2,627
Re: Z homing not retracting
« Reply #1 on: July 07, 2021, 12:31:53 AM »
homing sequence depends in most cases from Motion Controller you are using.
Mach3 with PP will only move until Limit Switch is cleared, without retract.
