Hello Guest it is November 19, 2026, 03:52:44 AM
Author Topic: 3D print plugin no Z axis.  (Read 18903 times)
« on: June 07, 2021, 03:47:13 PM »
Hey guys.
Been working on a large format printer. Mach 3 has run well for awhile. Setting up for printing, and the wizard is not slicing correctly. .stl loads properly in any other program, but when loaded into mach 3, there is 0 z commands. Slice says file says 300+ layers, but only shows 1. Attempted slicing, and importing g-code, same result.
« Last Edit: June 07, 2021, 03:52:07 PM by rekcd »
