Hello Guest it is November 13, 2026, 04:59:17 PM
Author Topic: Pokey57CNC Pendent signals  (Read 27988 times)
« on: June 05, 2021, 06:45:55 AM »
Before I set the pendent up I'd like to know if there is a way to change the value the Jog Step Increment signals.
I'd like to use the "Step x0.001" signal to have a value of 0.0001. Does the "Step x0.001" signal represent the Control General Config Jog Increment Position 4 or is it in the Pokeys code?
Thanks for any help.
Tony
Re: Pokey57CNC Pendent signals
« Reply #1 on: July 08, 2021, 11:13:32 AM »
If I'm not mistaken you will be adding a pendant  script to your start script you would change the value in your pendant script .
