Hello Guest it is October 21, 2026, 04:44:03 AM
Author Topic: Machine Home Limit Switch Trigger  (Read 21752 times)
« on: June 02, 2021, 02:10:09 PM »
I'm having an issue with Mach3 letting my machine slam into the z-axis limit switch, when fed a G28 line.
The machine has no issue referencing home and returning to zero. Anyone have any ideas as to where the issue may lie (software, hardware, wiring)?
Video:
https://www.youtube.com/watch?v=NZhciE4gUUw
Offline TPS
  •  2,627 2,627
Re: Machine Home Limit Switch Trigger
« Reply #1 on: June 03, 2021, 01:58:56 AM »
a G28 is nothing else then a move to specified home Position (Config->Homing/Limits) in machine coords.
if axis are given with G28 (G28 Z10) it will first move to the given Point and the to specified Position.
i have seen in your Video that you are using:
G91 G28 X0 Y0 Z0 in this case the given values are useless because G91 incremental but distances are 0.
if you have defined Z homepos (Config->Homing/Limits) to 0 it would be the same like G53 Z0
and it Looks like your Z0 is hitting the Limit Switch. you can try to define a -0,2 for Z just for a test.
