Hello Guest it is October 21, 2026, 06:47:28 AM
Author Topic: Mach3 pausing X when turning off coolant  (Read 21511 times)
« on: May 28, 2021, 11:22:19 AM »
I am trying to get my mill back up and running, Dry cutting programs to assure no lost steps etc.  It's a TAIG mil,, with 400oz steppers.  Should be ample power.  Rapids of 40IPM, and jogging everything is fine. I can go back and forth all 3 axis no issues.  run X 100x back and forth 1" with dial indicator and stops great.  BUT, when dry running a file, it uses flood coolant.  When prog starts, and coolant comes on, I mouse click to turn off and the X axis skips, for lack of better terminology.  Sometimes it'll go completely out of sync, other times it'll restart, with some missed steps.  I've tried different Kernal speeds and such.  Like I stated, Jog's are perfect.  40IPM,, accel is 5IPSPS.  Computer is a 2500mhz intel running XP.  No other progs running with Mach.
I
m pulling my hair out here.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Mach3 pausing X when turning off coolant
« Reply #1 on: May 30, 2021, 07:30:10 PM »
It sounds like noise from the pump motor or the relays switching the motor.
« Reply #2 on: May 31, 2021, 04:52:02 PM »
Thx,  I was tired, never even thught about unplugging pump, and testing controls without the 120v.  Ya  no errors there.  SO working on relocating the 120v relay away from motion board/stepper drives.
