Hello Guest it is November 29, 2026, 10:32:51 AM
Author Topic: Mach 4 XBOX360 controller plugin that doesn't require writing a LUA script ?  (Read 17581 times)
Hey!
Is there a Mach4 plugin or product that *doesn't* require writing a LUA script ? It's fine if the plugin uses LUA and the user is free to edit later but it would be good if it also gives a default configuration to start with.
Anything ?
Offline Bill_O
  •  616 616
Many of the Plugins and standard products don't require a custom LUA script.
The scripting happens when you want something different or special.
The options and what people want are just too varied.
Thanks Bill!  I found that the xbox controller plugin doesn't need Lua coding for basic configuration. For some reason, when I tried to configure the controller before it popped up a Windows game Controller config. Then when I looked around for info, I saw people writing LUA code to get basic capability. I can code but I didn't want to have to :)
I've activated the Mach4 XBox360-Plugin.
Then I've tried to jog the the Xbox and nothing happend at the motors.
diagnostics looks like in the Pic:
the end of the String is "no Command". have the buttons not yet been assigned?
thanks in advance
David
No, there are no defaults.  Configure->Plugins->Xbox Controller
Not Configure->Control plugins tab
it works. thank you!
