Hello
Guest
it is
October 22, 2026, 05:34:10 PM
Guest
Login
Register
Menu
Home
Help
Search
Login
Register
YouTube
Machsupport Forum
Mach Discussion
Mach4 General Discussion
Z axis always goes to the top
« previous
next »
Print
Pages:
1
Go Down
Author
Topic: Z axis always goes to the top (Read 5347 times)
aroff
2
on:
May 16, 2021, 08:57:39 AM »
First time run. I load the g-code from Aspire using the Avid Txt save file. When I try to run it sends the spindle to the top and resets
Please..what am i doing wrong. Have watched videos but to no avail
thank you
file included
Logged
Cbyrdtopper
985
Re: Z axis always goes to the top
Reply #1 on:
May 17, 2021, 10:34:32 AM »
Have you set your Tool Offsets and your Z Work Offset?
Your program says it should only go 0.8" above your Z Work Offset.
Logged
Chad Byrd
Print
Pages:
1
Go Up
« previous
next »
