Hello Guest it is October 24, 2026, 12:08:59 AM
Author Topic: Automatic Tool Height Setting from manual  (Read 5499 times)
« on: May 11, 2021, 11:24:12 PM »
Hello,
I tried to understand the example of automatic tool height setting from mach 4 scripting guide.
Code: [Select]
-- Auto Tool Setting Macro
 Requires the following instance registers to be defined
 TS_XPos-----------X position of probe (machine position)
 TS_YPos-----------Y position of probe (machine position)
 TS_Type-----------Offset type (1 or 2)
 TS_TouchPos-------Z position of touch off surface (machine position)
 TS_ProbeH---------Height of probe above touch off surface
 TS_DefaultL-------Default tool length guess
 TS_Retract--------Retract distance after probe touch
 Offset Type 1-----Length of tool from gauge line to tip
 Offset Type 2-----Distance from tip of tool to the touch position
--The function GetRegister() must be defined for use by macros
function m1005()
 ------------- Define Vars -------------
 local ProbeSignal = mc.ISIG_DIGITIZE
 ------------- Get current state -------------
 local CurTool = mc.mcToolGetCurrent(inst)
 local CurHNum = mc.mcCntlGetPoundVar(inst, 2032)
 local CurFeed = mc.mcCntlGetPoundVar(inst, 2134)
 local CurZOffset = mc.mcCntlGetPoundVar(inst, 4102)
26
 local CurFeedMode = mc.mcCntlGetPoundVar(inst, 4001)
 local CurAbsMode = mc.mcCntlGetPoundVar(inst, 4003)
 ------------- Get touch off parameters -------------
 local Xpos = GetRegister("TS_XPos", 1)
 local Ypos = GetRegister("TS_YPos", 1)
 local OffsetType = GetRegister("TS_Type", 1)
 local TouchPos = GetRegister("TS_TouchPos", 1)
 local ProbeHeight = GetRegister("TS_ProbeH", 1)
 local RetractDistance = GetRegister("TS_Retract", 1)
 local ToolLengthGuess = GetRegister("TS_DefaultL", 1)
 ------------- Check Probe -------------
 local hsig = mc.mcSignalGetHandle(inst, ProbeSignal)
 local ProbeState = mc.mcSignalGetState(hsig)
 if (ProbeState == true) then
 mc.mcCntlSetLastError(inst, "ERROR: Probe signal is activated")
 do return end
 end
 ------------- Calculations for Gcode -------------
 local StartHeight = TouchPos + ProbeHeight + ToolLengthGuess + .5
 ------------- Generate GCode -------------
 AutoToolSetGCode = ""
 AutoToolSetGCode = AutoToolSetGCode .. "G00 G80 G40 G49 G90\n"
 AutoToolSetGCode = AutoToolSetGCode .. "G00 G53 Z0.0\n"
 AutoToolSetGCode = AutoToolSetGCode .. string.format("G00 G53 X%.4f Y%.4f\n", Xpos, Ypos)
 AutoToolSetGCode = AutoToolSetGCode .. string.format("G00 G53 Z%.4f\n", StartHeight)
 AutoToolSetGCode = AutoToolSetGCode .. "G91 G31 Z-2.0 F25.\n"
 mc.mcCntlGcodeExecuteWait(inst, AutoToolSetGCode)
 --Check probe contact
 if (ProbeState ~= 1) then
 mc.mcCntlSetLastError(inst, "ERROR: No contact with probe")
 mc.mcCntlGcodeExecuteWait(inst, "G0 G90 G53 Z0.0\n")
 do return end
 end
 AutoToolSetGCode = AutoToolSetGCode .. string.format("G91 G00 Z%.4f\n", RetractDistance)
 AutoToolSetGCode = AutoToolSetGCode .. "G91 G31 Z-1.0 F10.\n"
 do return end
 end
 AutoToolSetGCode = AutoToolSetGCode .. "G90 G00 G53 Z0.0\n"
 ------------- Get touch position and set offset -------------
 local ZProbed = mc.mcCntlGetPoundVar(inst, 5063)
 local ZOffset = ZProbed - ProbeHeight + CurZOffset
 if (OffsetType == 1) then
 ZOffset = math.abs(TouchPos - ZOffset)
 end
 mc.mcToolSetData(inst, mc.MTOOL_MILL_HEIGHT, CurTool, ZOffset)
 mc.mcCntlSetLastError(inst, string.format("Auto tool setting complete, Offset = %.4f",
ZOffset))
I have a question about one variable : TS_ProbeH -> The height of probe above touch off surface.
I don't understand what is this variable...
I understand that the TS_TouchPos is the distance between the gage line of the spindle and the touch off surface of the sensor in machine position (-100 for example)
So could you please explain me how to use this variable ? Could someone can draw a schematic ?
Thank you for your help...
Rodolphe
