Hello Guest it is November 23, 2026, 04:51:25 AM
Author Topic: Need help Mach3 Plasma !!  (Read 12125 times)
« on: May 10, 2021, 12:49:47 PM »
I need help, please
There is a problem, which is when running the motors through the "Mach3 Mill" tab, the three motors work, and when operating from "Mach3 Plasma" the Z-axis motor does not work, and with this settings are compatible between them and the video explains the problem
Thank you
