Hello Guest it is October 24, 2026, 04:11:58 AM
Author Topic: How to setup Z safe in mach4  (Read 4913 times)
« on: May 04, 2021, 06:57:52 PM »
Can someone explain in a simple way how to set Safe Z in mach4. I am trying to set Z safe to 15mm but I am out of option. I use ESS smooth stepper as well.
I tried the G-Code for "Go to Zero" but not working. I just want the Z moves 10-15mm over Z before x and y reach 0 point. in Mach3 there was an option that you simply click and set the 15mm in Z safe and done. I guess Mach4 just want to make it hard.
