Hello Guest it is October 25, 2026, 01:12:47 PM
Author Topic: Tool Length Offset Macro Program  (Read 33703 times)
Re: Tool Length Offset Macro Program
« Reply #20 on: June 16, 2021, 01:32:31 PM »
Found the reference you were talking about. It was in the DOC directory for Mach4. It was very helpful in understanding variables in G code.
I think the problem might be with the variable to get the current tool number (#2029). When I look in Diagnostics->regfile-> and then # Variables, #2029 only shows 0.000. It doesn't matter what tool I change to.
Kenny
« Reply #21 on: June 16, 2021, 01:47:18 PM »
Yup, that could be it.  Like I said, it could be a version issue.  I haven't installed a new version of Mach4 on a mill in well over a year.  No need to if they're all running fine.
Chad Byrd
« Reply #22 on: June 17, 2021, 01:18:28 PM »
I had to contact mach4 support. They told me to use #1231 instead of #2029. Change the variable and now it works as it should  :).
Kenny
