Hello Guest it is November 22, 2026, 02:10:50 PM
Author Topic: pause btwn lines of code  (Read 16477 times)
Offline PCH
  •  80 80
« on: April 30, 2021, 05:57:15 PM »
For some reason my ellipse shapes are being milled with a slight hesitation between each line of code.  I have the constant velocity checked.  I have imported a dfx from Autocad into Bobad to generate code.  The ellipse in Bobcad is broken into segments and not a continuous line.  Not sure how to correct this.  Thought the constant velocity being generated in Mach3 would take care of this...any ideas out there!
Re: pause btwn lines of code
« Reply #1 on: May 02, 2021, 02:37:38 AM »
M3 can only do circular or helical interpolation on move like G02 i think, not elliptical. If your CAM generates curves as small straight segments using G01 M3 can't I believe link them together.
