Hello Guest it is November 07, 2026, 10:27:09 AM
Author Topic: mach3 intrface + final race  (Read 29372 times)
« on: April 28, 2021, 10:34:19 AM »
Hello, I am here again to ask for help that in this forum has always been good for me
I already installed the laser
Thank you
Now I am at the end of the race I have already done a thousand tests and I am not able to ride the end of the race I think I know position
red and black
but green I don't know where to connect
[img]
« Last Edit: April 28, 2021, 10:36:37 AM by tazmahv »
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: mach3 intrface + final race
« Reply #1 on: April 29, 2021, 08:28:41 AM »
Here is the diagram for the end stop board :-
« Reply #2 on: April 29, 2021, 08:39:27 AM »
thanks for reply
I know that green is a sign
what I do not know is where signal on plate mach3 interface board
or I don't know how to configure well
signal is pwm ????
« Last Edit: April 29, 2021, 08:41:02 AM by tazmahv »
  •  2,785 2,785
« Reply #3 on: April 29, 2021, 03:42:07 PM »
The green wire will go into one of the inputs.  The green wire will be 0 or 5V depending on the switch state.
Then configure ports and pins, Input Signals, X Home to Port 1 pin 10 or which of the 5 inputs you have used, It will be one of the following 5 pins 10,11,12,13 or 15
You may need to tick the Active low too.
You also need to put the Black to ground (GND) or 0V and the Red wire to +5 Volt.
« Last Edit: April 29, 2021, 04:00:00 PM by Graham Waterworth »
« Reply #4 on: April 29, 2021, 04:06:33 PM »
ok the final race issue is already solved
Thank you
