Hello Guest it is October 05, 2026, 08:14:04 AM
Author Topic: ip address PokeysCNC57E  (Read 27128 times)
« on: April 23, 2021, 06:37:58 PM »
Need help with suggestion for ip address for PokeysCNC57E.
I had to change the battery and no the ip address is lost.  Not able to get help from Polabs with no response from them for some reason.  When I set up my machine in 2018, Posupport suggested an ip address range and if worked well.  Can anyone suggest what to try.  Thanks
Re: ip address PokeysCNC57E
« Reply #1 on: April 24, 2021, 03:59:49 AM »
It is actually a PoKeys57E
Troubleshooting says  - Warning: Autoconfiguration IP address space (169.254.107.119) - check network card settings open network settings
    - Warning: Device uses invalid gateway IP configuration (0.0.0.0)
THanks
