Hello Guest it is October 22, 2026, 07:20:39 AM
Author Topic: Jog mode vs. Program mode  (Read 15931 times)
« on: April 21, 2021, 02:51:34 AM »
I make a homemade milling router and i adjust motor tuning and everything and in jog mode everything works fine,but when i change to program mode and insert g-code motors are producing bad sound and dont work good, they are folowing the conture i adjust motor steps and the path is ok, but the sound of the motors isn't. What can be the cause of that?,pls help.
Offline Graham Waterworth
  •  2,785 2,785
  • Yorkshire Dales, England
Re: Jog mode vs. Program mode
« Reply #1 on: April 21, 2021, 07:59:24 PM »
The Jog rate might be set at something less than 100%, Press the TAB key on the keyboard and make sure Jog is at 100% then retune your motors, making sure steps per are set correctly.
You can check movement with a Dial Clock and enter this code in MDI screen :-
Metric, Move 1mm from current position
G01 G91 X1. F25.
Inch, Move 50 thousands from current position
G01 G91 X.05 F1.
