Hello Guest it is October 18, 2026, 12:39:28 PM
Author Topic: Galil DMC-18x6 Linear Mode doesn't work  (Read 52170 times)
« on: April 08, 2021, 01:56:51 AM »
I use Galil DMC-18x6 with two ICM-2900 modules. In vendor original program (Optomec Work Station Control) I load minimal worked code like this:
Code: [Select]
REM Contours
VA 88200
VD 88200
VS 17640
LM YH
LI ,36505,,,,,,7091280
LE
BGS
AMS
If I remove first REM block or change first word "Contours" to another, program doesn't work. The axis goes to state "In motion" but actually nothing. If I keep this block it works correctly.
Then I put this program to Terminal (Galil WSDK) and load to controller. Block REM doesn't loaded to controller and I run this program with XQ command. The axis goes to state "In motion" but actually nothing. Command TS return "13, 141, 13, 13, 13, 13, 13, 141".
Another commands like PA, PR, JG work correctly from command mode and program mode.
What do I do wrong?
« Last Edit: April 08, 2021, 02:00:27 AM by dkotlyar »
Re: Galil DMC-18x6 Linear Mode doesn't work
« Reply #1 on: April 15, 2021, 07:52:54 AM »
I edit my program and try again.
First I add label #contours at begin and EN instruction at end of program. This doesn't works in my case.
Second I add switch coordinate system instruction CAS after label. And this doesn't works too.
Third I switch coordinate system to T and replace BGS and AMS to BGT and AMT. I got program like this:
Code: [Select]
#contours
CAT
VA 88200
VD 88200
VS 17640
LM YH
LE
BGT
AMT
EN
And this works for me!
Next I tried vector mode from user manual with T coordinate system and it's works too. Then I check other axis (in my machine it is X, Y, Z, W (table tilt) and H (table rotate) axis). All of them works correctly.
Question is done.
