Hello Guest it is November 20, 2026, 09:39:34 AM
Author Topic: My XML  (Read 9399 times)
My XML
« on: October 13, 2007, 11:54:54 AM »
Brian,
Can you look over this XML file for me and check to see if I have something wrong.  I really don't know what I'm doing with this yet.  I just uninstalled and reinstalled the software because I wasn't getting any reading in the Time in Int.  Now I am, anywhere from 2.9 to 5 something.  I've got the Gecko G340 drives hooked up and they are holding the servo motor.  But, when I jog with the keyboard, the DRO moves but not the motors.  There's still alot about this stuff that I don't know.  It's probably something stupid that I can't find or overlooked, but any help would be appreciated.  Thanks!
-Leith
Re: My XML
« Reply #1 on: October 13, 2007, 03:51:00 PM »
First thing I see is you only have the X axis enabled, if this axis is not moving then you need to check you have the correct wring to your breakout/drives.
