Hello Guest it is October 24, 2026, 08:31:36 PM
Author Topic: Mach 4/LUA Ethernet Explicit Messaging  (Read 5972 times)
« on: April 06, 2021, 09:16:00 AM »
Hi All,
I'm just curious for the time being if this is possible. I would like to interface Mach 4 to a servo drive which can communicate over Ethernet/IP. The motion control signals will be Step and Direction coming from an Ethernet Smoothstepper, however I can also pull diagnostic information over Ethernet *if* there is a way to form and transmit a generic ethernet packet using LUA in Mach 4.
I did something similar a few years back using the serial port to pull diagnostics out of a servo drive and that actually worked great, now I'd like to repeat the endeavour using a different servo drive and Ethernet/IP.
So the question is: does anyone know of a LUA function or library which supports read/write over Ethernet?
Thanks much,
Mike
Offline smurph
  •  1,575 1,575
Re: Mach 4/LUA Ethernet Explicit Messaging
« Reply #1 on: April 07, 2021, 11:24:21 PM »
Mach4 comes with the LuaSockets module that can do what you want.
http://w3.impa.br/~diego/software/luasocket/reference.html
Warning: It isn't for the feint or heart.  :(  But it is possible.
Steve
