Hello Guest it is November 17, 2026, 11:42:37 AM
Author Topic: Program changing between machines  (Read 118916 times)
« on: March 31, 2021, 12:03:57 PM »
I have Mach 3 installed on two machines. One I use for developing the Gcode and the other is installed on a PC connected to my CNC.  Both have Mach 3 Ver: R3.043.062 installed. The PC connected to the CNC has the plugin for NC Pod installed.   I was using CamBam to create my gcode and on the development PC, looks and runs great. When I op3en the gcode on my CNC PC, a large circle appears and is totally wrong.  I am at a total loss as to why the exact same gcode is interpreted differently. Any suggestions would be most welcome.  I've attached pictures of the issue.
Offline TPS
  •  2,627 2,627
Re: Program changing between machines
« Reply #1 on: April 01, 2021, 02:07:23 AM »
Config -> General Config -> IJ Mode is the same on both PC's?
