Hello Guest it is November 13, 2026, 12:41:18 PM
Author Topic: Help needed to engrave emblem...  (Read 35447 times)
« on: March 30, 2021, 11:36:03 PM »
  I have a Syil X6 VMC with Mach3 and ArtSoft version 3.00 and I need someone to walk me through how to load a picture of a minibike (hand drawn) into my machine and convert it into G-code so the image can be cut on large plastic key fobs.  Would someone please help me with this project?  It's for a minibike reunion.
Thank you kindly,
Mariah
  •  9,377 9,377
Re: Help needed to engrave emblem...
« Reply #1 on: March 31, 2021, 02:46:45 AM »
perhaps check out the free F-Engrave software and tutorials on their website; https://www.scorchworks.com/Fengrave/fengrave.html
This software can import .dxf drawings and convert to Mach compatable Gcode, etc. and should enable you to complete your minibike project with ease.
« Reply #2 on: March 31, 2021, 01:01:10 PM »
Thanks Tweakie, seems very complicated for my level.  Is there a simpler way for a novice?
Mariah
« Reply #3 on: March 31, 2021, 03:28:45 PM »
Can you post a copy of the picture(minibike). The process is not always easy. But sometimes you get lucky.
« Reply #4 on: March 31, 2021, 05:07:15 PM »
Here it is, just the center item not the text above or below it.
« Reply #5 on: March 31, 2021, 05:55:35 PM »
Try again      Give up cant even send a picture, machine will set another 10 years for mdi things
« Reply #6 on: March 31, 2021, 09:21:50 PM »
« Reply #7 on: March 31, 2021, 09:51:51 PM »
« Reply #8 on: April 01, 2021, 08:41:47 AM »
I thought you had a picture of the drawing of the minibike. You cannot work with that fuzzy picture on a shirt.
« Reply #9 on: April 01, 2021, 05:46:10 PM »
When I figure out if I can do this job on my mill I should be able to get a crisp image from the person who made the drawing.  Sorry for not mentioning that sooner.
