Hello Guest it is November 26, 2026, 04:53:02 AM
Author Topic: Lua: Error occurred while opening file  (Read 16543 times)
« on: March 30, 2021, 08:16:24 PM »
I'm using mach 4 with the pmdx-411 smartbob. Everything was working fine until today and every time I try to jog i get this error.
PMDX: DEVICE ERROR 'SYSTEM ERROR(7): Motion Underrun'
I also realized it was giving an error at startup
PMDX: Communication status 'Sync'd to Device'
cannot open C:\Mach4Hobby\Profiles\PMDXMILL\Macros\mcLua.mcc: No such file or directory
Im not sure what to do. Any help would be greatly appreciated
GOOMBA
Re: Lua: Error occurred while opening file
« Reply #1 on: March 31, 2021, 01:19:55 PM »
Disable the motion controller plugin for now.
Remove it from the directory all together.
Then put the attached file into the "Macros" folder inside your MACH4 directory.
MACH4 Hobby > desired Profile > Macros
Then start the profile again and let me know what happens.
Make sure to select Simulation mode again under motion controller selection.
