Hello Guest it is November 03, 2026, 05:04:17 PM
Author Topic: Mach3 Turn showing Mill options in Engine Config/Ports & Pins  (Read 26657 times)
Evening all.
I'm fairly new to Mach3 and specifically the turn version.  I have come across a little problem.
I added a few buttons onto the standard screenset (1024.lset).
If I now point my mouse to the Engine configuration / ports & pins; 'MILL OPTIONS' is there instead of 'TURN OPTIONS'.
How this manifested itself was that (all of a sudden), I realised the X axis was cutting on the radius and not the diameter as I had set.  Despite showing 'diameter mode' on the screen.
If you look at the two screen grabs, you'll see the difference.
Any help would be wonderful.
Kind regards
Jack
