Hello Guest it is November 10, 2026, 12:46:02 AM
Author Topic: goto zero  (Read 16536 times)
Offline moxy
  •  34 34
goto zero
« on: March 30, 2021, 02:40:17 AM »
Hi All,  when I press goto zero my X axis sets to 0.0025. This seems to shift the whole cut in the X direction. I am cutting a mold and the cuts are all in the same direction (left to right) After each cut the X axis is returned to 0 and the y axis increments a tiny amount and the next cut is moved to the right a small amount. This is not a gcode action. If I jog x about 120 mm then goto zero the x axis returns perfectly but the dro shows x at 0.0025? Weird! Any suggestions?
Offline TPS
  •  2,627 2,627
Re: goto zero
« Reply #1 on: March 30, 2021, 05:48:34 AM »
what is your steps/per Setting on this axis?
witch Units are you in (imperial/mm)?
Offline moxy
  •  34 34
Re: goto zero
« Reply #2 on: March 30, 2021, 07:18:29 AM »
I found that My connections to the gecko's caused the loss of position. I was using ground as the common and should have set the dir signal to active high. I still have to check the 0.0025 thing on the goto zero but I suspect that that was also the cause. The steps per mm are around 400 and change. Thanks for your interest
Les
