Hello Guest it is November 26, 2026, 05:10:37 AM
Author Topic: How to Create a Simple Dialog Box  (Read 9833 times)
« on: March 28, 2021, 12:58:04 PM »
Another seemingly simple issue that I can't figure out after searching for a couple hours. In Lua, I want to create a modal dialog box with OK and Cancel buttons. I assume I can then use the return value in an IF statement afterward. It seems I could use a wxMessageDialog with wxOK and wxCancel buttons. I just can't find a good example or description of how you do this.
Offline smurph
  •  1,575 1,575
Re: How to Create a Simple Dialog Box
« Reply #1 on: March 29, 2021, 12:58:11 PM »
Well, it is not as simple as it would first seem unless you know wxLua like the back of your hand.  I would use wxFormBuilder to create the dialog and paste it into your code.  Use a wxDialog as your base and make the buttons call EndModal(myReturnCode) where myReturnCode is what you want the modal dialog to return.  It could be some stock value like wx.wxID_OK or wx.wxID_CANCEL, or some custom value you create.
Do a search on wxFormBuilder in this forum and read up on it.
Steve
« Reply #2 on: March 29, 2021, 08:16:59 PM »
Thank you for the response. I'll have to see if I can get creative and work around the need for a dialog box. If not, guess I'll need to learn more.
Thanks Again!
« Reply #3 on: March 30, 2021, 02:12:42 AM »
of all of the features of Lua I find wx.Lua the hardest to get my head around.
There is very good reference material, for geeks, by geeks and in geekese!
I found the first few faltering steps were when I copied and pasted some of the dialogues in LuaExamples. In particular I found
the file dialogue useful. I experimented with it until  understood each of the parameters and their syntax. It was slow but I got several
very useful macros which I now use daily.
At smurphs suggestion I did experiment with wxFormBuilder. I have spent about six hours on it so far, but probably need to spend
a lot more to become familiar with it. The adavantage is that you can see wxWidget code, which in conjunction with the reference material,
you can start to de-mystify it all.
raig
Offline jbuehn
  •  101 101
« Reply #4 on: March 30, 2021, 11:32:09 AM »
If your OK and CANCEL buttons can be YES and NO instead, you could use something like this...
Code: [Select]
local response = wx.wxMessageBox("Message", "Title", wx.wxYES_NO)
if (response == 2) then
    -- user said YES
else
    -- user said NO
end
