Hello Guest it is October 03, 2026, 01:49:23 AM
Author Topic: macro correction help  (Read 40902 times)
« on: March 23, 2021, 03:06:00 PM »
good evening
I have this macro for zero tool / tool change positioned in a button, gives me an error, is there anyone who could correct it for me?
since it is not in my capacity, I thank anyone who could help me
Sub Main
   Speak ("selezionare zero     o     cambio UTENSILE") 'Avviso Vocale
 Begin Dialog SelectCentering 420,120,160,96,"MACRO UTENSILE"
   OKButton 30,68,40,14
   CancelButton 90,68,40,14
   GroupBox 30,5,100,52,"ZERO / CAMBIO UTENSILE",.GroupBox1
   OptionGroup .OptionGroup1
   OptionButton 46,24,80,8," ZERO UTENSILE",.OptionButton1
   OptionButton 46,40,80,8," CAMBIO UTENSILE"  ,.OptionButton2
  End Dialog
  Dim Dlg1 As SelectCentering
  Button = Dialog (Dlg1)
  If Button = 0 Then Exit Sub
  Selected  = Dlg1.OptionGroup1
  'laser is selected@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
  If Selected = 0 Then
     'Tool Height Setting Macro - JLH v1.1 - 4 March 2013
   'Questa versione ha un approccio a 2 fasi, veloce per la velocita e lenta per la precisione.
   Speak ("confermare ZERO UTENSILE") 'Avviso Vocal
        Sleep (1000)
        Begin Dialog ButtonSample 250,200,120,60," "
   OKButton 12,20,40,14
   CancelButton 68,20,40,14
End Dialog
   Dim Dlg2 As ButtonSample
   Button = Dialog (Dlg2)
   If Button = 0 Then
   MsgBox "ZERO UTENSILE CANCELLATO"
    Speak (" ZERO   UTENSILE     CANCELLATO") 'Avviso Vocale
   Exit Sub
End If
   Message "************  INIZIO ZERO UTENSILE ************"
'----- USER VARIABLES FOR DISTANCES, FEED RATES, TOUCH PLATES, OPTIONS ---------------------------------------
If GetParam("Units") = 0 Then
 '* METRIC VALUES *
 VarUnits = "  MM"
 VarMaxDistance = -25.4      'MAX Z TRAVEL * ALWAYS MAKE NEGATIVE
 VarFeedRate = 127      'MM/MIN DOWN FEEDRATE
 VarStandOff = 1.27      'STANDOFF DISTANCE ABOVE PROBE CONTACT
 VarTouchPlate = 20.066      'PRIMARY/DEFAULT TOUCH PLATE THICKNESS
 VarSecondPlate = 0.038      'SECONDARY TOUCH PLATE THICKNESS * OPTION FOR CHOICE DIALOG
 VarThirdPlate = 0.012      'TERTIARY TOUCH PLATE THICKNESS * OPTION FOR CHOICE DIALOG
Else
 '* SAE VALUES *
 VarUnits = " INCH"
 VarMaxDistance = -1.0      'MAX Z TRAVEL * ALWAYS MAKE NEGATIVE
 VarFeedRate = 5      'INCH/MIN DOWN FEEDRATE
 VarStandOff = 0.05      'STANDOFF DISTANCE ABOVE PROBE CONTACT
 VarTouchPlate = 0.79      'PRIMARY/DEFAULT TOUCH PLATE THICKNESS
 VarSecondPlate = 0.0015   'SECONDARY TOUCH PLATE THICKNESS * OPTION FOR CHOICE DIALOG
 VarThirdPlate = 0.0005      'TERTIARY TOUCH PLATE THICKNESS * OPTION FOR CHOICE DIALOG
End If
VarRunTheChoice = 1      'RUN PLATE CHOICE DIALOG?  0=NO  1=YES
VarDelayInSec = 0      'DEFAULT SECONDS TO DELAY MOTION
VarBeepOrSpeak = 2      'COUNTDOWN AUDIO: 0=NONE 1=BEEP 2=SPEAK
VarSecOfAudio = 5      'COUNTDOWN SECOND AT WHICH AUDIO BEGINS
VarCompleteAudio = 3      'END SIGNAL: 0=NONE 1=BEEP 2=SPEAK 3=WAV_AUDIO_FILE
VarWavAudioFile = "C:\MACH3\ToolCompleteSND1.wav" 'WAV_AUDIO_FILE LOCATION
'----- GET INITIAL ENVIRONMENT SETTINGS FOR LATER REINSTATEMENT ----------------------------------------------
VarInitialLinearMode = GetOemDRO(819)        'LINEAR MODE  G00/G01
VarInitialDistMode = GetOemLED(48)           'DISTANCE MODE G90/G91
VarInitialFeedRate = GetOemDRO(818)          'FEEDRATE
VarInitialInhibit = GetParam("ZInhibitOn")   'Z INHIBIT STATUS  OFF/ON
VarInitialZScale = GetParam("ZScale")        'Z SCALE VALUE
VarInitialFRO = GetOemDRO(821)           'FEEDRATE OVERRIDE PERCENTAGE
Message ""                      'CLEAR STATUS LINE TEXT
'----- CHECK DIGITIZE STATE; 0=CLEAR 1=ACTIVE ----------------------------------------------------------------
If GetOemLED (825) <> 0 Then
 RET = MachMsg("Digitize Status Not Clear. Check Probe/Connections And Try Again!","*** ERROR! ***",0)
 End      'END SCRIPT
End If
'----- CHECK IF USER WANTS TO RUN PLATE CHOICE DIALOG --------------------------------------------------------
If VarRunTheChoice = 1 Then RunTheThing 'RUN SUBROUTINE
'----- ACTIVATE TIME DELAY IF USED ---------------------------------------------------------------------------
If VarDelayInSec <> 0 Then
 Do Until VarDelayInSec = 0      'LOOP UNTIL SECONDS = ZERO
  Message VarDelayInSec         'DISPLAY SECONDS VALUE IN STATUS LINE
   If VarDelayInSec < VarSecOfAudio + 1 Then
   Select Case VarBeepOrSpeak
         Case 1 'OPTION BEEP
          Beep
         Case 2 'OPTION SPEAK
            Speak(VarDelayInSec)
        End Select
   End If
  Sleep 1000      'PAUSE 1 SEC.
  VarDelayInSec = VarDelayInSec - 1   'REDUCE SECONDS BY 1 AFTER EACH LOOP
 Loop
End If
'----- PREPARE FOR MOVE ----- MOVE PROBE DOWN TOWARD CONTACT -------------------------------------------------
SetParam("ZInhibitOn",0)   'TURN Z INHIBIT OFF
SetParam("ZScale",1.0)      'SET Z SCALE TO 1.0
DoOemButton(1014)      'CANCEL FEED OVERRIDE
SetOemDRO(802,0)        'ZERO Z AXIS DRO
Sleep 200         'DELAY TO ALLOW DRO TO CHANGE
Message "Auto Tool Zero Running..."
Code "G90 G31 Z" &VarMaxDistance &"F" &VarFeedRate   'MOVE DOWN @ FEEDRATE
 While IsMoving()      'WAIT UNTIL MOVE IS COMPLETE BEFORE PROCEEDING
 Wend
'----- GET Z CONTACT POSITION AND TEST FOR MAX TRAVEL ------ MOVE TO STANDOFF ------ UPDATE Z AXIS DRO -------
If GetVar(2002) <= VarMaxDistance + .001 Then
 RET = MachMsg("Maximum Travel Reached. Reposition Z Axis Closer To Touch Plate And Try Again!","*** OOPS! ***",0)
 Message ""
 RETURNSTATE    'CALL REINSTATE SUBROUTINE
 End      'END SCRIPT
Else
 Beep
 Code "G90 G0 Z" &GetVar(2002)   'MOVE TO CONTACT POINT DUE TO OVERRUN
  While IsMoving()
  Wend
 Sleep 200
 Code "G90 G0 Z" &VarStandOff   'MOVE TO STANDOFF DISTANCE
  While IsMoving ()
  Wend
 SetOemDRO(802, VarStandOff + VarTouchPlate)     'SET Z DRO (STANDOFF + PLATE THICKNESS)
 Sleep 200
  Select Case VarCompleteAudio
    Case 1 'OPTION BEEP
      Beep
      Speak("Tool Zero Complete.")
    Case 3 'OPTION WAV_AUDIO_FILE
      PlayWave(VarWavAudioFile)
  End Select
 Message "Auto Tool Zero Complete! ***Remove Touch Plate***"
End If
End      'END SCRIPT
'******************************************* SUBROUTINES BELOW ***********************************************
'----- SUBROUTINE TO RETURN INITIAL SETTINGS -----------------------------------------------------------------
Sub RETURNSTATE
 'REINSTATE INITIAL FEEDRATE
 Code "F" &VarInitialFeedRate
 'REINSTATE DISTANCE MODE  0=G91  -1=G90
 If VarInitialDistMode = 0 Then Code "G91" Else Code "G90"
 'REINSTATE LINEAR MODE  0=G00  1=G01
 If VarInitialLinearMode = 0 Then Code "G00" Else Code "G01"
 'REINSTATE Z INHIBIT STATUS 0=OFF 1=ON
 If VarInitialInhibit = 1 Then SetParam("ZInhibitOn",1)
 'SET Z SCALE TO INITIAL VALUE
 If VarInitialZScale <> 1.0 Then SetParam("ZScale",VarInitialZScale)
 'SET FEEDRATE OVERRIDE TO INITIAL VALUE
 If VarInitialFRO <> 100 Then SetOemDRO(821,VarInitialFRO)
End Sub
'----- DIALOG SUBROUTINE FOR TOUCH PLATE CHOICE AND TIME DELAY -----------------------------------------------
Sub RunTheThing
  Dim PlateList$ (2)   'DECLARE 3 ITEM ARRAY FOR PLATE SIZE LIST
    'MM FORMATTING FOR LISTBOX
   PlateList (0) = Format(VarTouchPlate,"00.000")     'FILL ARRAY 1
   PlateList (1) = Format(VarSecondPlate,"00.000")   'FILL ARRAY 2
   PlateList (2) = Format(VarThirdPlate,"00.000")     'FILL ARRAY 3
  Else
    'INCH FORMATTING FOR LISTBOX
   PlateList (0) = Format(VarTouchPlate,"0.0000")     'FILL ARRAY 1
   PlateList (1) = Format(VarSecondPlate,"0.0000")     'FILL ARRAY 2
   PlateList (2) = Format(VarThirdPlate,"0.0000")     'FILL ARRAY 3
  End If
 Dim UnitList$ (0)   'DECLARE 1 ITEM ARRAY FOR UNIT LISTBOX
   UnitList (0) = VarUnits     'FILL ARRAY 1
 'SETUP DIALOG CONTROLS
 Begin Dialog PlateChoice 110,68,"Touch Plate"
    ListBox 15,20,35,30, PlateList$(),.Lstbox2
   ListBox 64,20,25,10, UnitList$(),.Listbox1
    GroupBox 8,8,95,45,"Choose Plate Thickness",.GroupBox1
   OKButton 57,34,37,12
   Text 13,55,100,15, "Delay"
   TextBox 37,55,30,10, .SecText
        Text 70,55,30,15, "Seconds"
 End Dialog
 Dim Dlg1 As PlateChoice
 Dlg1.SecText = VarDelayInSec   'FILL SECONDS TEXTBOX WITH DEFAULT VALUE
  Button = Dialog (Dlg1)   'SHOW DIALOG AND WAIT FOR BUTTON REPLY
  If Button = 0 Then   'IF CLOSE BUTTON
   Message "Auto Tool Zero CANCELED"
   End      'END SCRIPT
  End If
  'CHECK THAT SECONDS WAS ENTERED NUMERIC
  If IsNumeric(Dlg1.SecText) = True Then
        VarDelayInSec = Int(Dlg1.SecText)
  Else
   RET = MachMsg("*****  SECONDS MUST BE ENTERED IN NUMERIC FORMAT! *****", _
   "  Substance Abuse Is Not Recommended  ",0)
   RunTheThing   'RESTART SUB
  End If
 'SET PLATE VARIABLE BASED ON PLATE CHOICE
 PlateNum = Dlg1.Lstbox2
 Select Case PlateNum
      Case 0 'PRIMARY PLATE
        'WILL USE PRIMARY/DEFAULT THICKNESS
      Case 1 'SECONDARY PLATE
         VarTouchPlate = VarSecondPlate
      Case 2 'TERTIARY PLATE
        VarTouchPlate = VarThirdPlate
 End Select
End Sub
  End If
  'web is selected@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
  If Selected = 1 Then
       Rem CAMBIO UTENSILE AUTOMATICO
   Speak ("confermare cambio utensile automatico") 'Avviso Vocale
   Sleep (1000) ' pausa di 1 secondi
   Dim Dlg3 As ButtonSample
   Button = Dialog (Dlg3)
   If Button = 0 Then
   MsgBox "CAMBIO UTENSILE AUTOMATICO  CANCELLATO"
    Speak (" CAMBIO UTENSILE   AUTOMATICO      CANCELLATO") 'Avviso Vocale
   Exit Sub
End If
   If Not GetLed (7) Then         ' è referenziato X
   vxled = 1
   End If
   If Not GetLed (8) Then         ' è referenziato Y
   vyled = 1
   End If
   If Not GetLed (9) Then         ' è referenziato Z
   vzled = 1
   End If
   Tled = vxled + vyled + vzled
   If Tled = 3 Then         ' se non sono referenziati X, Y e Z esco
   ' parametri lavorazione
   ToolPathOnOff = 132         ' mi carico la definizione del tasto tool path
   xzero = GetDRO (30)         ' memorizzo la posizione iniziale ASSOLUTA di cambio utensile
   yzero = GetDRO (31)
   zzero = GetDRO (32)
   xpos = GetDRO (0)         ' memorizzo la posizione iniziale RELATIVA di cambio utensile
   ypos = GetDRO (1)
   zpos = GetDRO (2)
   fpos = GetDRO (18)         ' memorizzo il feedrate iniziale
   ' variabili del programma
   fmax = 500            ' imposto il feedrate massimo
   fmin = 50            ' imposto il feedrate per la palpata
   zavv = -40            ' distanza rapida di avvicinamento al palpatore
   zmin = -150            ' profondità oltre il palpatore
   xcut = 0            ' posizione X per cambio utensile
   ycut = 0            ' posizione Y per cambio utensile
   xtool = GetUserDRO (1200)      ' posizione X del palpatore (Settings -> Tool Change Location)
   ytool = GetUserDRO (1201)      ' posizione Y del palpatore
   ztool = GetUserDRO (1202)      ' posizione Z del palpatore
   ' inizio programma
   Call DoOEMButton (ToolPathOnOff)   ' disabilito il tool path
   code "G0 F" & fmax         ' porto il feedrate al valore massimo
   Code "G1 G53 Z0"         ' porto Z a ZERO macchina
   While IsMoving()
   Wend
   Call SetDro (2,0)         ' porto il contatore Z a zero
   code "G1 G53 X" & xtool & "Y" & ytool    ' mi allineo sul palpatore
   While IsMoving()
   Wend
   code "G1 Z" & zavv         ' scendo in avvicinamento (fino a zavv)
   While IsMoving()
   Wend
   code "G0 F" & fmin         ' porto il feedrate al minimo
   If IsSuchSignal (22) Then      ' scendo sul palpatore per vedere la misura della punta attuale
      code "G31 Z" & zmin
      While IsMoving()
      Wend
   End If
   zuno = GetVar (2002)         ' memorizzo il valore di Z della punta attuale
   zsu = zuno + 2
   code "G0 Z" & zsu         ' salgo per la seconda misura
   While IsMoving()
   Wend
   If IsSuchSignal (22) Then      ' scendo per la seconda volta per vedere la misura della punta attuale
      code "G31 Z" & zmin
      While IsMoving()
      Wend
   End If
   zdue = GetVar (2002)         ' memorizzo il valore di Z della punta attuale
   zorig = (zuno + (zdue)) / 2
   code "G0 F" & fmax         ' riporto il feedrate al massimo
   code "G1 G53 Z0"         ' porto Z a ZERO macchina
   While IsMoving()
   Wend
   code "G1 G53 X" & xcut & "Y" & ycut   ' vado in una posizione comoda per il cambio utensile
   While IsMoving()
   Wend
Speak ("ora si puo' cambiare la punta") 'Avviso Vocale
MsgBox ("ORA SI PUO' SOSTITUIRE LA PUNTA")
Speak ("attenzione      e' stata sostituita la punta") 'Avviso Vocale
Response = MsgBox ("E' STATA SOSTITUITA LA PUNTA?", 4 , "ATTENZIONE")
   If (Response = 6) Then
   i = 99
   Else
   Speak ("ATTENZIONE , LA PUNTA NON E' STATA SOSTITUITA, RIPRENDO IL LAVORO CON LA PUNTA INIZIALE") 'Avviso Vocale
   MsgBox ("LA PUNTA NON E' STATA SOSTITUITA RIPRENDO IL LAVORO CON LA PUNTA INIZIALE")
End If
If i <> 99 Then               ' non faccio nulla
   code "G1 G53 X" & xzero & "Y" & yzero   ' torno alla posizione X Y zero pezzo
   While IsMoving()
   Wend
   code "G1 X" & xpos & "Y" & ypos      ' torno alla posizione X Y da dove ero partito
   While IsMoving()
   Wend
   code "G1 G53 Z" & zzero         ' riporto Z al valore zero pezzo
   While IsMoving()
   Wend
   code "G1 Z" & zpos         ' riporto Z al valore di partenza
   While IsMoving()
   Wend
   code "G0 F" & fpos         ' riporto il feedrate al valore di partenza
   Speak ("ATTENZIONE , CAMBIO UTENSILE NON EFFETTUATO , SI PUO' RIPRENDERE LA LAVORAZIONE") 'Avviso Vocale
   MsgBox ("LA PUNTA NON E' STATA SOSTITUITA")
   'DoSpinCW()            ' riaccendo il motore M3 e riprendo il lavoro da dove l'avevo lasciato
Else
   While IsMoving()
   Wend
   While IsMoving()
   Wend
      code "G31 Z" & zmin
      While IsMoving()
      Wend
   End If
   zuno = GetVar (2002)         ' memorizzo il valore di Z della nuova punta
   zsu = zuno +4
   While IsMoving()
   Wend
   If IsSuchSignal (22) Then      ' scendo per la seconda volta per vedere la misura della nuova punta
      code "G31 Z" & zmin
      While IsMoving()
      Wend
   End If
   zdue = GetVar (2002)         ' memorizzo il valore di Z della nuova punta
   znew = (zuno + (zdue)) / 2
      code "G1 G53 Z0"      ' ritorno Z ZERO macchina
      While IsMoving()
      Wend
   code "G0 G53 X " & xzero & "Y" & yzero   ' torno alla posizione X Y zero pezzo
   While IsMoving()
   Wend
   code "G0 X " & xpos & "Y" & ypos      ' torno alla posizione X Y da dove ero partito
   While IsMoving()
   Wend
   zdif = zorig - (znew)         ' controllo se l'utensile è più corto o piu lungo
   code "G1 G53 Z" & zzero-(zdif)      ' riporto Z al valore zero pezzo con la differenza utensile
   While IsMoving()
   Wend
   Call SetDro (2,0)         ' porto contatore Z a zero
   code "G1 Z" & zpos         ' riporto Z al valore di partenza (inizio programma)
   While IsMoving()
   Wend
      Speak ("CAMBIO UTENSILE EFFETTUATO ,   SI PUO' RIPRENDERE LA LAVORAZIONE ,      RIMUOVERE PIASTRA") 'Avviso Vocale
   MsgBox ("RIMUOVERE PIASTRA E PREMERE IL TASTO LAVORAZIONE")
   Message "************ CAMBIO UTENSILE EFFETTUATO ************"
End If
Else
   speak ("Per poter cambiare l'utensile bisognava prima aver referenziato la macchina" )
   MsgBox ("PER CAMBIARE LA PUNTA BISOGNAVA REFERENZIARE LA MACCHINA")
End If
Call DoOEMButton (ToolPathOnOff)   ' abilito il tool path
   End If
   Exit Sub
End Sub
Offline TPS
  •  2,627 2,627
Re: macro correction help
« Reply #1 on: March 24, 2021, 02:16:33 AM »
Code: [Select]
Sub Main()
End Dialog
        Sleep (1000)
End Dialog
If Button = 0 Then
Exit Sub
End If
'* METRIC VALUES *
VarUnits = "  MM"
Else
'* SAE VALUES *
VarUnits = " INCH"
End If
End      'END SCRIPT
End If
Case 1 'OPTION BEEP
Beep
End Select
End If
Loop
End If
End If
If Button = 0 Then
Exit Sub
End If
vxled = 1
End If
vyled = 1
End If
vzled = 1
End If
yzero = GetDRO (31)
zzero = GetDRO (32)
ypos = GetDRO (1)
zpos = GetDRO (2)
' inizio programma
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
code "G31 Z" & zmin
While IsMoving()
Wend
End If
zsu = zuno + 2
While IsMoving()
Wend
code "G31 Z" & zmin
While IsMoving()
Wend
End If
While IsMoving()
Wend
While IsMoving()
Wend
i = 99
Else
End If
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
Else
While IsMoving()
Wend
While IsMoving()
Wend
code "G31 Z" & zmin
While IsMoving()
Wend
End If
zsu = zuno +4
While IsMoving()
Wend
code "G31 Z" & zmin
While IsMoving()
Wend
End If
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
End If
Else
End If
   End If
   Exit Sub
Wend
Message ""
End      'END SCRIPT
Else
Beep
While IsMoving()
Wend
Sleep 200
While IsMoving ()
Wend
Sleep 200
Case 1 'OPTION BEEP
Beep
End Select
End If
'End      'END SCRIPT
End Sub
Sub RETURNSTATE
End Sub
Sub RunTheThing
Else
End If
End Dialog
End      'END SCRIPT
End If
Else
End If
End Select
End Sub
« Reply #2 on: March 24, 2021, 03:10:05 AM »
thanks TPS for the answer, now it works but in the window it doesn't give the data anymore
Offline TPS
  •  2,627 2,627
« Reply #3 on: March 24, 2021, 03:30:19 AM »
this macro is a copy and paste nightmare for each programmer
Code: [Select]
Global VarUnits
Global VarMaxDistance
Global VarFeedRate
Global VarStandOff
Global VarTouchPlate
Global VarSecondPlate
Global VarThirdPlate
Sub Main()
End Dialog
        Sleep (1000)
End Dialog
If Button = 0 Then
Exit Sub
End If
'* METRIC VALUES *
VarUnits = "  MM"
Else
'* SAE VALUES *
VarUnits = " INCH"
End If
End      'END SCRIPT
End If
Case 1 'OPTION BEEP
Beep
End Select
End If
Loop
End If
End If
If Button = 0 Then
Exit Sub
End If
vxled = 1
End If
vyled = 1
End If
vzled = 1
End If
yzero = GetDRO (31)
zzero = GetDRO (32)
ypos = GetDRO (1)
zpos = GetDRO (2)
' inizio programma
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
code "G31 Z" & zmin
While IsMoving()
Wend
End If
zsu = zuno + 2
While IsMoving()
Wend
code "G31 Z" & zmin
While IsMoving()
Wend
End If
While IsMoving()
Wend
While IsMoving()
Wend
i = 99
Else
End If
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
Else
While IsMoving()
Wend
While IsMoving()
Wend
code "G31 Z" & zmin
While IsMoving()
Wend
End If
zsu = zuno +4
While IsMoving()
Wend
code "G31 Z" & zmin
While IsMoving()
Wend
End If
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
End If
Else
End If
   End If
   Exit Sub
Wend
Message ""
End      'END SCRIPT
Else
Beep
While IsMoving()
Wend
Sleep 200
While IsMoving ()
Wend
Sleep 200
Case 1 'OPTION BEEP
Beep
End Select
End If
'End      'END SCRIPT
End Sub
Sub RETURNSTATE
End Sub
Sub RunTheThing
Else
End If
End Dialog
End      'END SCRIPT
End If
Else
End If
End Select
End Sub
« Reply #4 on: March 24, 2021, 03:51:48 AM »
thank you for your patience, now another problem
Offline TPS
  •  2,627 2,627
« Reply #5 on: March 24, 2021, 04:33:31 AM »
maybe
Code: [Select]
Global VarUnits
Global VarFeedRate
Global VarStandOff
Sub Main()
End Dialog
        Sleep (1000)
End Dialog
If Button = 0 Then
Exit Sub
End If
'* METRIC VALUES *
VarUnits = "  MM"
Else
'* SAE VALUES *
VarUnits = " INCH"
End If
End      'END SCRIPT
End If
Case 1 'OPTION BEEP
Beep
End Select
End If
Loop
End If
Wend
Message ""
End      'END SCRIPT
Else
Beep
While IsMoving()
Wend
Sleep 200
While IsMoving ()
Wend
Sleep 200
Case 1 'OPTION BEEP
Beep
End Select
End If
End If
If Button = 0 Then
Exit Sub
End If
vxled = 1
End If
vyled = 1
End If
vzled = 1
End If
yzero = GetDRO (31)
zzero = GetDRO (32)
ypos = GetDRO (1)
zpos = GetDRO (2)
' inizio programma
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
code "G31 Z" & zmin
While IsMoving()
Wend
End If
zsu = zuno + 2
While IsMoving()
Wend
code "G31 Z" & zmin
While IsMoving()
Wend
End If
While IsMoving()
Wend
While IsMoving()
Wend
i = 99
Else
End If
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
Else
While IsMoving()
Wend
While IsMoving()
Wend
code "G31 Z" & zmin
While IsMoving()
Wend
End If
zsu = zuno +4
While IsMoving()
Wend
code "G31 Z" & zmin
While IsMoving()
Wend
End If
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
While IsMoving()
Wend
End If
Else
End If
End If
End Sub
Sub RETURNSTATE
End Sub
Sub RunTheThing
Else
End If
End Dialog
End      'END SCRIPT
End If
Else
End If
End Select
End Sub
« Reply #6 on: March 24, 2021, 04:49:23 AM »
keeps giving me the error "block = F, otherwise it works
« Reply #7 on: March 24, 2021, 04:54:24 AM »
if it is easier to modify the "INCH" part I don't care it could be deleted
Offline TPS
  •  2,627 2,627
« Reply #8 on: March 24, 2021, 05:09:53 AM »
you have to run the macro in vb scripter window by using the >|| button (single step) to see where the error occurs.
without having your Hardware here it is hard to test the macro for functionality.
« Reply #9 on: March 24, 2021, 06:00:54 AM »
I ran the macro in the window> || it passes all the lines and always returns to the beginning, if I execute it from the button it works fine but at the end "block = F" comes out. I noticed that in the initial window the entry "delay" is empty (in the original macro there is "0"). could this be the problem?>
